Reply 58820 of 58833, by Shader_BiH
informatyk wrote on 2026-04-23, 11:59:
After years of searching, I finally found a Compaq Prolinea in perfect condition and good price. It has 12 MB of RAM and probably the original 300 MB hard drive, on which the German version of Windows 95 RTM was installed.
I now need to find a way to install a 5.25-inch floppy drive, but it’s missing some unusual mounting rails.
I love that front power switch... Feels much better than these modern micro switches.
I picked up this old clone from a friends balcony today... The case is nothing to write home about but the hardware seems decent
It's been outside for a while so I'll give it 24h before firing it up. The PSU is definitely a weird one. No detailed specs to show but there is some diagram on the top
Reply 58821 of 58833, by ubiq
Shader_BiH wrote on Yesterday, 16:16:
I love that front power switch... Feels much better than these modern micro switches. […]
Heh, I absolutely had that exact case back in the day. Came with a P75 - multiplier unlocked and able to run at 100 MHz no worries. Made it last until I was able upgrade to a PII-350.
Reply 58822 of 58833, by ubiq
CharlieFoxtrot wrote on Yesterday, 05:38:
I have 4/50@66 as well as Deskpro XE 466. Both use the same chassis, they have only slightly different front plates and naturall […]
I have 4/50@66 as well as Deskpro XE 466. Both use the same chassis, they have only slightly different front plates and naturally motherboards. I’m personally a big fan of these 93-94 Compaqs, they were still from the era when these big manufacturers hadn’t raced to the bottom and these systems still had high build quality. As LPX style computers, these also have nice small desk footprint. And as MB has all the important things integrated, the three ISA slots are usually just fine. I also have Presario 425 AIO with originial peripherals. I do wish that that system would have three ISA slots instead of the two.
I also originally installed 5.25 floppy drive on my system, but I changed it to PAS16 multimedia kit, that is PAS16 sound card and MediaVision branded Sanyo 2x SCSI cd-rom. I also have NIC and MPU-401 card installed in it, both of which are quite common with my 486 builds. In fact, I network all my vintage boxes as it just makes life so much easier with data transfers.
If you can access 3D printer, there should be printable rails in thingiverse (or printables, can’t remember which).
You also might be interested with this project, if you have the correct motherboard:
https://github.com/wichers/Compaq-Cache-Module-197005-001
Compaq (197005-001) cache module - open source reproduction
You most likely don’t have original cache module, so adding thah reproduction module gives a nice boost on some games and applications.
Awww, I momentarily got pretty excited as I have an identical-looking Deskpro XE 450 - but nope, that project only works with Presarios. ☹️ Pretty cool for those who can benefit though!
Reply 58823 of 58833, by Mandrew
Got one of the most undesirable monitors of all time, the VGA monochrome. This one is a Sunshine MO-14 with a nice and bright CRT.
Reply 58824 of 58833, by weedeewee
Mandrew wrote on Yesterday, 18:08:
I guess that one mixes the three color channels which makes it a little bit less undesirable.
Do not ask Why !
Reply 58825 of 58833, by Shader_BiH
Don't know why it would be undesirable... but it's got a lot of charm. That "Low radiation" writing in the corner 🤣
Reply 58826 of 58833, by BitWrangler
weedeewee wrote on Yesterday, 18:37:
Though Trident cards will do that if they only sense 75ohm load on the green pin.
Reply 58827 of 58833, by BitWrangler
They were a little desirable back in the day for the following reasons, i) they were much shorter and lighter than colour, an advantage when space was a problem while still maintaining screen size. ii) they were low fatigue for poring over logs or dumps in console. iii) the discount over a colour monitor was relatively huge if you were trying to save a buck.
Reply 58828 of 58833, by CharlieFoxtrot
BitWrangler wrote on Yesterday, 18:54:
I had a BW VGA monitor with my Amstrad PC 2086. The most annoying thing with it was that as most VGA software wasn't designed for BW, the palette used could cause issues with the BW display. For example, bright red looks like black on the BW monitor and if you have for example red font on black background... good luck.
Otherwise I found it a pleasant display to look at.
Reply 58829 of 58833, by Repo Man11
You lucked into getting a legendary Socket 7 motherboard for free! Oldie Tuning: Asus P55T2P4 with AMD K6-2+/500
Reply 58830 of 58833, by H3nrik V!
ubiq wrote on Yesterday, 17:34:
A P75 doesn't need to be multiplier unlocked to run 100, that would be going from 1.5x50 to 1.5x66 MHz FSB. Must've felt like it was flying, since the rest of the system was faster too.
Reply 58831 of 58833, by tehsiggi
zuldan wrote on 2026-04-22, 11:36:
tehsiggi wrote on 2026-04-21, 15:00:
Can't wait for it to arrive.
Can’t wait to see the repair process. When does it arrive?
Naive me hoped for today. It would have been. However upon delivering the parcel DHL decided it's not according to their delivery standards.
Sa, 25.04.2026, 08:41
Leider ist eine Zustellung der Sendung nicht möglich, da sie nicht unseren Versandbedingungen entspricht. Die Sendung wird an den Absender zurückgeschickt.
It's going back to the seller now. I am disappointed and my day is ruined 🙁 Perhaps I can pick at least the 9800Pro with XT layout up today.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 58832 of 58833, by zuldan
tehsiggi wrote on Today, 08:06:
Oh no I’m devastated too 🤣. What bad luck man.
Reply 58833 of 58833, by tehsiggi
zuldan wrote on Today, 08:30:
Finally i can engage in mails again to get my order.. I missed it so much.. Not..
