First post, by my03
i have the LTE5300 and i use it with windows 98. I recall that i had to struggle a bit to find the proper ESS drivers working in W98 (i tried a bunch of options. They mostly installed ok, but didn't provide any audio output. In the end, i managed to find an older driver (v4.04) that worked ok with windows).
I keep hearing that this laptop is very good for dos gaming. However, i have a very hard time getting the machine to recognize any audio capabilities at all when running dos (w98 dos). I have tried the various ESS utilities (ESSCFG, etc) but they will not even detect any audio in the machine from dos.
Is it possible even? I assume so given all the praise for this laptop, but how do one go about making it so?`I'm clueless. Any good pointers that you can provide?
