Ethernet NICs for retro systems
First post, by songoffall
So what happens after I save a bunch of white box PCs from recycling is I take them completely apart, clean them and examine them for leaky/bulgy caps, replace those and store them as parts until I get a chance to test them.
And the last batch had a very nice NIC from 1996 - Netgear FA310TX, an early version with DEC Tulip chip. Thought it would be a very nice addition to my Pentium II 1997 build, but once I got to the drivers, I was quite surprised to find the abundance of systems supported by this NIC - it had DOS, Windows 3.1, Windows 9x, Novell NetWare, OS/2, SCO Unix, and apparently early Linux versions too. And it is 10-base-T with 10/100 support. This is not the case with most NICs I stumble upon. So I might have stumbled upon something special here.
The nicest other NIC I have is 3com 3C905CX-TX-NM, took hell to make it work (needed a bit of love and a lot of deoxit), which offloads a lot of work from the CPU and has very nice software.
And I have a bunch of TP-Link TF-3239Ds, which are good enough for late-90s to 2000s Windows 98/XP systems. But I feel like that's not going to be enough once I start adding older systems to the network.
And as I'm restoring this Dell PowerEdge 2300 server to serve as a central node to my retro network, I wonder if there's nice server-grade PCI NICs or even PCI switches I could use.
What's your experience?
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
Reply 1 of 33, by megatron-uk
For PCI, the Intel Ether express 10/100/1000. You can get drivers for nearly every OS, including packet drivers for native Dos.
There are other gigabit nics with Dos support, but the Intel cards are usually easiest to find and have the widest array of software.
For ISA I typically stick to Realtek Rtl8019/8029 or 3com 3c509 for the same reasons - ubiquitous software support.
https://www.target-earth.net
Reply 2 of 33, by NeoG_
I bought a generic RTL8139D PCI NIC for $2 on ebay just because the listing said it has Win98 drivers but I found out after it's also supported by pretty much every OS under the sun (DOS, Win 3.1, Win95, Win98/ME, NT3.51, NT4, XP, Vista, 7, SCO Unix, Linux, MacOS, NetWare 3/4/Client). There are also heaps of them around.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 3 of 33, by songoffall
megatron-uk wrote on 2026-04-26, 06:55:
Thanks.
That still leaves me without a proper chonky preferrably 2-port PCI card for my server though. Doesn't feel right, putting a tiny low profile Realtec or Intel into that huge box.
Reply 4 of 33, by megatron-uk
Why the need for two ports? Are you using it as a gateway or router, or configuring it with link aggregation to a switch?
If you want more bandwidth then instead of 802.3ad / 802.1ax aggregation you're probably better off getting a switch with at least one 2.5G port and getting a cheap 2.5G NIC for your server. I bought a 6 port 2.5G switch the other day for £30 delivered, and cards (Realtek, admittedly) are like £10-12. It doesn't make sense to buy old server network hardware anymore - it's no cheaper and it's often much, much hotter/power hungry; things like the typical Intel X520 NIC's are monstrous power hogs compared to modern stuff.
Reply 5 of 33, by Disruptor
songoffall wrote on 2026-04-26, 06:10:
Can you post a picture of this card please?
Reply 6 of 33, by Grzyb
No.
It's common for NICs to have support for a wide range of systems.
The only notable exception is my personal most-hated NIC ever - 3CSOHO100B.
Officially, only supports Windows ME, 2000, and XP.
Unofficially, also works with 98SE, and Linux.
The perfect NIC for a Windows ME troll-build 🤣
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 7 of 33, by DaveDDS
Over the years I've had good luck with RealTek, both ISA and PCI editions, I particularily like them being NE2000 compatible, which (IMHO) is just about the most common/supported NIC in various classic systems.
Intel, Dlink, SMC, WD and others have also been good.
PKTDRV.ZIP on my site has a decent collection of dozens of packet drivers I've found most useful with classic systems, as well as a tool called PCINIC which finds, identifies and reports configuration (addresses etc.) for PCI networking cards (information you need to install some packet drivers)
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 8 of 33, by songoffall
Disruptor wrote on 2026-04-26, 08:26:
I will photograph the one I have once I open up the old Pentium II PC. But here's a picture of the same exact card from the internet:
The attachment 71unLW-cQSL._SL1500_.jpg is no longer available
Unlike other Netgear FA310TX cards, the chip is not marked as Netgear, clearly marked as DEC and there is no yellow Netgear mascot stencil on the back. Unlike later LiteOn based FA310TX cards, there's a second IC on the board. The option rom socket on my card is unpopulated as well.
Reply 9 of 33, by songoffall
megatron-uk wrote on 2026-04-26, 07:34:
To connect the server to two networks at the same time. Nothing practical, just to build something fun.
Reply 10 of 33, by Disruptor
songoffall wrote on 2026-04-26, 13:42:
Does that mean you have two NIC in your computer?
Reply 11 of 33, by fosterwj03
I like the Dec 21140 chip because it's one of the few PCI network interfaces that have Windows NT 3.1 drivers.
Reply 12 of 33, by nali
I love the 3Com 3C905, because it can directly boot from Lan.
Of course some other cards do it too with a AllInOne floppy, but it's very useful.
And of course there are drivers for most of old OS.
Reply 13 of 33, by Disruptor
Well, there is the famous Cogent EM110 TX/T4.
One one PCI card you have:
10 Base 2 (BNC) thin wire
10 Base 5 (AUI) thick wire
10 Base T (TP) cat 3 full-duplex
100 Base T4 (TP) cat 3 half-duplex
100 Base TX (TP) cat 5 full-duplex
Reply 14 of 33, by songoffall
Disruptor wrote on 2026-04-26, 17:13:
Not in the Compaq, no.
Reply 15 of 33, by Grzyb
Disruptor wrote on 2026-04-26, 18:32:
Well, there is the famous Cogent EM110 TX/T4. One one PCI card you have: 10 Base 2 (BNC) thin wire 10 Base 5 (AUI) thick wire 10 […]
Very nice!
3C905B-COMBO is also worth mentioning - supports almost all of the above, the exception being 100 Base T4.
Reply 16 of 33, by DaveDDS
fosterwj03 wrote on 2026-04-26, 17:24:
I've got a few Realtek {mumble - I can figure out the model number if anyone cares} that are PCI and are fully NE2000 compatible, which is compatible with almost all OSs. It's been years, but I'm pretty sure they worked on NT 3.1, 4, 2000 also used them with Wfw 3.1, 95, 98 etc.
Heck I even use them in DOS with an NE2000 packet driver.
Reply 17 of 33, by aVd
Grzyb wrote on 2026-04-27, 00:09:
Very nice!
I have one of these 3Com EtherLink III 3C509B-C(ombo) NIC adapters. It's an ISA card, so it's suitable for even more vintage systems. Its configuration can be set by software tool. Also it supports boot ROM - I'm using it with XTIDE BIOS.
EDIT: Mistakenly swapped the numbers in NIC's model.
what comes around goes around
Reply 18 of 33, by Grzyb
DaveDDS wrote on 2026-04-27, 03:28:
Linux "ne2k-pci" driver supports the following:
RealTek RTL-8029(AS)
Winbond 89C940
Compex RL2000
KTI ET32P2
NetVin NV5000SC
Via 86C926
SureCom NE34
Winbond W89C940F
Holtek HT80232
Holtek HT80229
Winbond W89C940(misprogrammed)
Yes, they should work even with a not-PCI-aware NE2000 driver, you just need to specify the I/O address and IRQ manually, which may change after adding/removing other cards.
Reply 19 of 33, by Grzyb
aVd wrote on 2026-04-27, 06:58:
I have one of these 3Com 3C905B-C(ombo) NIC adapters. It's an ISA card, so it's suitable for even more vintage systems.
3C509B is ISA.
3C905B is PCI, and its COMBO variant is a rare example of 100 Mbps card with AUI and BNC ports.
