The problem is I need to take the GPU heatsink off to get access to the resistors to see if they are the same but I don't know how this butterfly style plastic clip works. I've squeezed the plastic piece behind the board but I can't lift the clips out.
The attachment IMG_20260426_131457.jpg is no longer available
Alright I got the GPU heatsink off. I used plyers to squeeze the plastic closer together (behind the board) and used some masking tape around the clips so I didn't damage the board if I slipped.
Glad I got it off because the factory thermal paste was in a shocking state. The core temperature went from 60c to 52c (used a thermal cam).
The attachment Heatsink off.jpg is no longer available
That's sweet. I had no idea the Ti200 could be modded into a Ti500.
I have two of the original GeForce3 (faster than Ti200). I don't see any value in touching them with a soldering iron, and wonder if they can be flashed to Ti500 without physical changes?
Milestones [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i5) → x86-64(i7) ] * original lost
Test increasing core and memory frequency in Windows (Coolbits registry to enable overclocking in nVidia control panel)
I own the Hercules 3D Prophet III since January of 2002. It's in storage since 2005. Should I try it?
Depends on which version you have, many Ti200s came with 5ns memory. The one the OP has (Prolink PixelView GeForce3 Ti 200) actually came with 4ns memory so why the mod works, I have a Medion Geforce 3 Ti200 with 5ns memory so it refuses to clock up that high. With standard Geforce 3 cards I think they vary, when I look up Hercules 3D Prophet III GF3 standard it looks like they had 3.8ns according to a iXBT Lab review.
zuldanwrote on 2026-04-27, 08:44:Test increasing core and memory frequency in Windows (Coolbits registry to enable overclocking in nVidia control panel) […] Show full quote
The main thing is to keep an eye on memory and your core’s temperature .
Once you have confirmed your card is stable at the frequencies you want then flash the BIOS with matching frequencies
Good job on the core over clock, I know the core overclocks much easier than the memory but in reviews I saw anandtech managed 215/490 MHz and iXBT Labs managed 200/500 MHz
If you want to try for more I have and old bookmark I had to look up on wayback as its gone now. (as was the anandtech one above)
I saw those reviews and was surprised because the reviewers couldn’t get the clock speeds I am getting. I didn’t have high hopes.
Thanks for that link. I’ve it saved! Not sure if I want to go to that extent of overclocking. Might save it for a Ti200 that’s in really bad shape (when I come across one).
I just overclocked a Inno3D Tornado 128MB Ti200 to a Ti500, and again it’s super stable. Either I’m just getting lucky or it’s pretty common for Ti200’s to overclock easily.
I see Inno3D Tornado 128MB Ti200 have 4ns memory as well, even most the Medion Ti 200s I see online have 4ns memory but mine alias does not and I did see a few other Medion Ti 200s that were like mine with 5ns memory.
GF3 series always benefited more from memory clocks then core clocks
Not a big deal as I have a set of Ti200, GF3, Ti500 so never felt the need to over clock that particular card. Many many years back I picked up a bunch of GF3 standard cards for cheap and those should all clock to TI 500 or higher speeds if I feel the need. GF3 tends to be the cards I put in my systems for testing.
