First post, by JAKra85
Hello Everyone,
I have stability issues with this ABit AB-PB4 board mentioned.
I must always re-seat the VGA and even then it only boots 2 times out once every 10 tries.
Tried multiple video card vendors and models.
What I have found out is that when I set the same CPU (AMD X5-133) to 486 DX4-100 it works; NOT flawlessly sometimes (rarely) it looses BIOS settings and boots with BIOS defaults (even with new CMOS battery).
In 486 DX4-100 mode (the CPU is still AMD X5-133) it boots every time.
Now I try to figure out why. 😀
The MB is running on an older (1995) B8 BIOS. The latest available is F2 from 1996.
Had anyone else similar issues that was solved?
Thanks!
Retro PC Gallery:
https://docs.google.com/document/d/1ara32t4rV … nU/edit?tab=t.0
Reply 1 of 7, by Chkcpu
Hi JAKra85,
Your Am5x86 issue can very well be caused by the ‘B8’ BIOS. If this is an Award BIOS from 10/1995 or earlier, it won’t have proper Am5x86 support.
What do you see as detected CPU on the BIOS boot screen? When the Am5x86 is supported, the Award BIOS should indicate “Am5x86-P75-S” when the multiplier is set to x4 mode, and “Enhanced Am486DX4-S” when the x3 mode is set.
If you don’t see Am5x86-P75, you need to upgrade the BIOS. All three 1996 BIOSes (C5, D2, and F2) at TRW support the Am5x86.
Cheers, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 2 of 7, by JAKra85
Chkcpu wrote on 2026-04-28, 12:45:
Hi JAKra85, […]
Hi JAKra85,
Cheers, Jan
Hello Jan,
Thanks for the confirmation! I was thinking the same thing!
- Correct, this is now it is reported.
Yesterday I requested a friend of mine to write me the F2 BIOS and send it to me.
In my opinion this old B8 BIOS does not handle the x4 multiplier well with this CPU, it's unstable.
I've tested with two CPUs and here is my conclusion:
CPU1
-Am5x86-P75-S (160MHz - 40x4) booting issue and unstable. (Reported as Am5x86-P75-S )
-Am5x86-P75-S (133MHz - 33x4) booting issue and unstable. (Reported as Am5x86-P75-S )
-Am5x86-P75-S (100MHz - 33x3) NO more booting issues, boots every time and stable. (Reported as Enhanced Am486DX4-S)
(I could not set this CPU to 120MHz to test that too, its 100 or 133.)
CPU2
-AMD 486DX4 (120MHz - 40x3) NO booting issues, boots every time and stable.
-AMD 486DX4 (100Mhz - 33x3) NO booting issues, boots every time and stable.
Will update this topic in the coming weeks with the results.
Kind Regards,
Attila
Retro PC Gallery:
Reply 3 of 7, by JAKra85
This board is very capricious when dealing with Am5x86-P75-S (133MHz) and (ATi) PCI based videocard!
I now have 3 boards:
ABit AB-PB4 - Rev 1.3 (1995 - B8 - BIOS)
ABit AB-PB4 - Rev 1.3 (1995 - 5E - BIOS)
ABit AB-PB4 - Rev 1.5 (1996 - D2 - BIOS)
The Rev 1.3 behave very similarly. Regardless of the BIOS version.
I do not recommend running any CPU above 486-DX4, or run the AMD X5-133 CPU at 100MHz (33x3). (no issues with F2 BIOS)
Rev 1.5 runs very stable with Am5x86-P75-S (133MHz) and PCI video.
There are still issues with some ATi PCI videocards!
Multiple ISA based card - no issues, boots all the time.
ATi Mach64 VT - sometimes (rarely) it boots, when it does it is stable.
ATi Mach64 GT (3D Rage) - no issues, boots all the time.
ATi Mach64 GT2 (3D Rage II) - no issues, boots all the time.
Also, the Rev 1.5 board supports 50Mhz base clock.
Runs stable at 150 MHz (3x50!) with ATi Mach64 GT2. 😉
The latest BIOS should arrive in a few days (1996 - F2). I will do more tests write the results here for future enthusiasts and "close the case".
Retro PC Gallery:
Reply 4 of 7, by Chkcpu
Hi Attila,
Thanks for the update.
As both v1. 3 boards still have an older BIOS version, it will be interesting to see if the F2 BIOS will fix the stability issues on these boards.
Looking forward to your next test results.
Cheers, Jan
Reply 5 of 7, by JAKra85
With the latest BIOS available there are no more PCI and booting issues when using Am5x86-P75-S CPU! 😀
BIOS:07/03/96-ALI-1487/89-2A4KDA1BC-F2
Double and triple tested on all motherboards Rev 1.3.
Rev 1.5 board died a few weeks ago when playing with OC... TIP127 transistor on it's way to revive it.
As a side note: 512K cache with (4 x IS61C1024-15N) is not supported even on the latest BIOS. Boots and hangs after memory count.
Retro PC Gallery:
Reply 6 of 7, by Chkcpu
Hi Attila,
Thanks for reporting back and good to hear that updating to the F2 BIOS fixed your issues on the Rev 1.3 boards!
I hope you can revive that Rev 1.5 board as well.
All the best, Jan
Reply 7 of 7, by JAKra85
Chkcpu wrote on 2026-06-14, 11:39:
Hi Attila, […]
Hi Attila,
All the best, Jan
Hello Jan,
Rev 1.5 board is alive again, working nicely.
No more fooling around... stock 133 is perfect.
Will send this v1.5 MB to TheRetroWeb, only Rev 1.3 has a picture.
With Kind Regards,
Attila
Retro PC Gallery:
