Reply 20 of 32, by Marco Pistella
Falcosoft wrote on Today, 08:43:
At that test e.g. 'space' would be a better option.
Confirmed — spacebar will be added as an alternative toggle key in the next build. It maps cleanly to a fixed scancode (39h) regardless of layout, which is exactly what the keyboard handling in X-VESA requires. Minimal change, no side effects.
Reply 21 of 32, by mwdmeyer
Is there specific hardware age you are interested in? I have lots of ISA/PCI machines.
Reply 22 of 32, by marxveix
mwdmeyer wrote on Today, 12:12:
Do we have a list, what tested already or all cards are good?
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 23 of 32, by SScorpio
Marco Pistella wrote on Today, 11:32:
Regarding the dump option: it's a reasonable request and I'll keep it in mind for future development. For now, the F2 key saves a screenshot in IFF-PBM format at any point in the program
— PBM2PNG.EXE (included in the archive) converts it to PNG, which is easy to attach to a post.
I'm not sure of your end goal vision on all the data that's collected. But I could see a database of some sort. If the card allows it being able to see the video bios revision versus the test results which might uncover when things were fixed/broken on various hardware.
Just something to think about and plan for the future.
Reply 24 of 32, by Marco Pistella
Everything is welcome — ISA, PCI, AGP, no age limit in either direction. If I had to prioritize: ISA cards with real analog oscillators are particularly interesting for the timing analysis (Command 4), as they produce very different jitter signatures compared to modern GPU VGA emulation. But honestly, any real hardware you can throw at it is useful data.
Reply 25 of 32, by Marco Pistella
SScorpio wrote on Today, 12:14:
I'm not sure of your end goal v...[CUT]
The hardware bug database is already part of the distribution — X-VESA.TXT includes a documented set of confirmed anomalies with card identification, BIOS version where available, and the specific behavior observed. It will grow with the beta.
A more structured database correlated with BIOS revisions is an interesting long-term idea — it would require a critical mass of data points per card family to be meaningful, which is exactly what a wide beta like this could start to build. Something to think about for the GitHub release phase.
Reply 26 of 32, by mwdmeyer
Marco Pistella wrote on Today, 12:40:
Claude code has help me write https://starrts.vogonswiki.com/ which includes Win 9x submit feature (json via HTTP to my server). I'm building in a submit feature for DOS soon too (there will be helper exe file to upload the results, based on mtcp). Planning to add to Git repo in future but happy to help if you think this is of interest to you.
Reply 27 of 32, by mwdmeyer
Here is from a Matrox Mill 2 8mb.
Reply 28 of 32, by Marco Pistella
mwdmeyer wrote on Today, 13:18:
Thank you — clean results on the Millennium II. A few notes:
PMID detected via 4F0Ah but not via BIOS direct detection: this is a known asymmetry on some VESA 2.0 implementations and X-VESA handles it correctly.
σ/μ = 0.0058 at 640×400 — slightly different from my own unit (0.0063 on the same card). Small variation, likely different production batch or thermal conditions at test time. Both values are consistent with healthy analog hardware.
8 MiB VRAM confirmed via direct probe, matching the declared value — no anomalies.
Could you run Command 4 on a higher resolution mode (0103 or 0107) as well? I'm curious whether σ/μ scales with horizontal frequency on this card.
BETA 2 UPDATE — attached to this post.
Changes:
- Spacebar added as alternative toggle key (Command 😎
- Dual-page and virtual resolution tests now distinguish between
"4F07h not supported" and "4F07h supported but failed" (014Fh)
Reply 29 of 32, by Falcosoft
Marco Pistella wrote on Today, 13:37:
... BETA 2 UPDATE — attached to this post. Changes: - Spacebar added as alternative toggle key (Command 8) - Dual-page and virtu […]
Changes:
Thanks, I have just tested it and everything works as expected 😀
Website, Youtube
VST Midi Driver Midi Mapper
Reply 30 of 32, by Tiido
This looks absolutely excellent ! I'm not gonna have any time to test it anytime soon unfortunately, but I do have a lot of various hardware to try things on when I finally am able to in a few months.
I appreciate the handwritten assembly aspect, it is something I am doing myself although I have not yet tried to do anything past real-mode yet, but unreal mode is in my todo list ~
Reply 31 of 32, by wierd_w
I'll test it on the asus x401u anachonistic laptop after work today. It claims vbe3.0, up to 1024x768, with a 32mb framebuffer. It's some integrated radeon derivative baked into an amd E1 cpu.
I've noticed it has strange behavior in jazz jackrabbit. (Jumping, tearing)
I'll do tests with, and without, mtrrlfbe enabling 32bit writes. (Though quake really benefits from 32bit writes being enabled.)
Reply 32 of 32, by konc
Great news! I was also using V1.0.2, mostly to test for defective video memory after upgrades with questionable chips or changing clocks.
Here's were I learned about it, and the file is still attached.
