Reply 2520 of 2523, by Falcosoft
zaphod77 wrote on Today, 04:42:
i think it's because i'm on windows 11. […]
you are on windows 10, and it works.
messing with compatibility didn't help.
for my final test i'm closing down chrome completely.
didn't matter. tyrus 1,256,000,000 ver and vampire do not load, and it's definitely the 32 bit player
test version didn't change anything.
I meant a screenshot about the ...About box where the versions can be seen.
BTW, I have just tested also the newest test version on Win 11 and it works perfectly :
The attachment vampire_w11.png is no longer available
Some things you can try:
1. Try to run FSMP as Administrator (although this is not needed, maybe it can show what kind of problem you have).
2. Make sure the dll is not blocked by Windows (blocked state is the default for downloaded files).
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2521 of 2523, by zaphod77
and after the reboot no vstis are playing any audio with midiplayer6!
okay that seems to be caused by running the test version.
Reply 2522 of 2523, by Falcosoft
okay rebooting my computer did fix it.
But it seems m-audio gm module and hypecanvas vsti don't load. hypercanvas requests to be reinstalled twice, and then shows the "not a 32 bit" error, and m-audio gm module gives an access violation. both function with savihost.
I have just noticed your edit.
I have also tested Roland/Edirol HyperCanvas and it also works perfectly:
The attachment hsc.png is no longer available
So you should check the usual things...
I do not know what 'm-audio gm modul' is so I could not test it.
There must be some serious problems with your system... What kind of Antivirus do you have? It seems some files are randomly blocked on your system.
BTW, VSTi plugins use the same audio path as SF2 soundfonts. So you should check what audio hardware is selected and what mode is selected (WASAPI/Diretsound) on the 'Device settings' dialog.
Website, Youtube
Reply 2523 of 2523, by zaphod77
okay got audio working again. that was annoying. I'm not too worried about hyper canvas. i think the issue is probably DRM related. the m-audio gm module is supposed to be hardware locked.
