First post, by Anaxagoras
- Newbie
Hello guys!
I'm trying to rescue my first laptop and I found that the RTC battery is totally discharged.
Since this I've been looking information about this and as I can read in the user guide the RTC battery is charging meanwhile the laptop is plugged at least for 24 hours.
I tried it but it does not work.
OK, no problem, it seems that I need to replace it but I have a doubt because I don't know if I can do it with a normal battery or rechargeable.
As far as I known a normal battery will be damaged if I try to charge, right?
Another thing, is this "hack" safe? https://www.youtube.com/watch?v=5DdAZrTZjEM
Thanks a lot
