First post, by aVd
Here is what I have about so called "S3 BIOS bright bug". The information is gathered form different sources (including one related thread in this forum and not using a.i. slop/web-searches):
For the older S3 video cards based on Trio64V2/DX (86C775), Trio64V2/GX (86C785), ViRGE/DX (86C375), ViRGE/GX (86C385) chips the "pedestal bit" in 0x03C5 register is this one: x x B x x x x x (the sixth bit, if we count from the least significant bit starting from one).
So, to cure the "bright bug" in the safest way, we have to use bitwise operation "AND 0xDF" (oxDF = 1 1 0 1 1 1 1 1) applied to the register 0x03C5. This way we don't change any other previously set bit values in the register:
Working assembly code for disabling "bright bug" on S3 Trio64V2/DX, Trio64V2/GX, ViRGE/DX, ViRGE/GX
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,1A
OUT DX,AL
INC DX
IN AL,DX
AND AL,DF ; dis. BB
OUT DX,AL
The safest reverse bitwise operation enabling "bright bug" for the same older S3 card is with "OR 0x20" (0x20 = 0 0 1 0 0 0 0 0) applied to the same register 0x03C5. This way we don't change any other previously set bit values in the register:
Working assembly code for enabling "bright bug" on S3 Trio64V2/DX, Trio64V2/GX, ViRGE/DX, ViRGE/GX
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,1A
OUT DX,AL
INC DX
IN AL,DX
OR AL,20 ; en. BB
OUT DX,AL
Important note: The above doesn't apply to the very first ViRGE/325 (86C325) chip! Possibly due to different register's settings.
For the newer S3 cards based on ViRGE/GX2 (86C357), Trio3D (86C365) and possibly even Savage3D, Savage4 chips the "pedestal bit" in 0x03C5 register is this one: x x x x B x x x (the fourth bit, if we count from the least significant bit starting from one).
In this case, to cure the "bright bug" in the safest way, we have to use bitwise operation "AND 0xF7" (oxF7 = 1 1 1 1 0 1 1 1). We don't change any other previously set bit values in this register:
Working assembly code for disabling "bright bug" on S3 ViRGE/GX2, Trio3D
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,27
OUT DX,AL
INC DX
IN AL,DX
AND AL,F7 ; dis. BB
OUT DX,AL
The safest reverse bitwise operation enabling "bright bug" for the same newer S3 cards is with "OR 0x08" (0x08 = 0 0 0 0 1 0 0 0):
Working assembly code for enabling "bright bug" on S3 ViRGE/GX2, Trio3D
MOV	DX,3C4
MOV AL,8
OUT DX,AL
INC DX
MOV AL,6
OUT DX,AL
DEC DX
MOV AL,27
OUT DX,AL
INC DX
IN AL,DX
OR AL,8 ; en. BB
OUT DX,AL
The pre-build DOS com-executables along with the source code for MASM and NASM will be attached in the next post.
what comes around goes around
Reply 1 of 1, by aVd
DOS binaries for the older S3 video cards based on Trio64V2/DX (86C775), Trio64V2/GX (86C785), ViRGE/DX (86C375), ViRGE/GX (86C385) chips:
DOS binaries for the newer S3 cards based on ViRGE/GX2 (86C357), Trio3D (86C365) and possibly even Savage3D, Savage4 chips:
