CGA graphics card in PCI slot?
Reply 20 of 29, by BitWrangler
How many LUTs for a 6845 emu/simu/clone ???
FPGA found on PCI parallel card, possibilities???
Reply 21 of 29, by Grzyb
furan wrote on 2026-04-21, 23:28:
I don't know why we're talking about supporting a theoretical additional cga card that is pci though - at this point just make a nice vga core that has extra cga/hercules bells and whistles.
wierd_w wrote on 2026-04-22, 00:16:
Many people want to drive a vintage CRT, which you cannot do with VGA signals.
Again: the idea is to re-create Mach32 functionality.
Additionally, install both VGA and TTL connectors, just like on many early VGA clones.
Reply 22 of 29, by BitWrangler
Well you can use Tomi Engdahls VGA2TV to get VGA chipsets to put out 15khz. Some of the early PCI chipsets should work with it, CL GD5434 is a cert, but not sure about others, Trident TGUI maybe. So out of those need to find the one with best CGA support. Then it's a matter of TTL conversion of the VGA output. This gets you a picture on a CGA tube, but not entirely sure if it's "real CGA" in number of lines... since it's emulated CGA that would be line doubled for VGA getting scan converted to CGA rates.
Reply 23 of 29, by kaposzta
Thank you all for your replies! 😀 What I really want is maybe not a PCI CGA card, but a VGA card with almost perfect CGA emulation.
The PCI Ati Mach32 was mentioned, I'll try to get one. Would it work if I put a Trio64 and a Mach32 into the same PC? I would plug the VGA cable to either one of them, depending on which game I want to play, then I would turn the computer on. Or can I unplug the cable while the PC is running and plug it in the other card? I'm wondering if that would do any harm to the PC or to the screen.
Reply 24 of 29, by weedeewee
kaposzta wrote on 2026-04-24, 13:48:
No, I highly doubt it will work.
I'm certain the VGA bioss will cause problems, that and the fact that both vga cards will likely expect to be the only vga card in the system, thus causing no boot or strange boot display issues.
Even if one card is pci and the other is AGP.
Do not ask Why !
Reply 25 of 29, by Grzyb
From what I recall, it's possible to use two PCI VGA cards at the same time.
The first one is assigned all requested resources: VGA compatible + PCI specific
The second one: PCI specific only
With normal DOS software, you can only use the first one.
The second one is available for systems with multiple-display support, eg. Windows 98.
I don't know whether it's possible to choose which of the cards should be the first one...
Edit: with PCI VGA + AGP VGA, it should work as above, additionally there's the "Init display first: PCI/AGP" BIOS option.
Reply 26 of 29, by BitWrangler
2 PCI cards does work, but maybe not until PCI 2.0, triton chipsets at least. Win98SE makes it easy to do dual monitor, but prior OS will probably be a mess. However, POST and dos console should initialise on whichever have monitor plugged in. Some picky picky motherboards might give you the beeps for not having a monitor plugged into one of them, whichever it thinks is more important. Beware if you use a VGA switcher that it's not a fancy one with resistors to fake monitor presence, otherwise the selection by monitor connection may not work that way. I'd recommend something like that though to save VGA socket wear.
Reply 27 of 29, by furan
BitWrangler wrote on 2026-04-24, 16:59:
I don't see why you need PCI 2.0. I/O decode and memory decode are just config space bits there in the original spec. Sudley software's support for dual PCI in 386SWAT only checks PCI version to decide what config space access mechanism to use.
https://github.com/sudleyplace/386SWAT/blob/m … r/DPCI/DPCI.ASM
Reply 28 of 29, by BitWrangler
Being in the spec and having the spec fully implemented are two different things. Take a look at RS232 spec and compare it to PC serial port sometime. I am not even sure 430FX handles it very well, last FX I ran "for serious" was always getting it's device enumeration knickers in a twist and needing reset.
Reply 29 of 29, by furan
this is "pc lore" not fact finding - I'm out
