First post, by foax
Networking is hard, especially networking in DOS. It can be fiddly to set up. So I took my knowledge and experience of DOS networking and jammed it all into this little kit! It contains everything you need to get IPX, TCP/IP, and Kali up and running in DOS.
Included in the kit:
  • Guides on how different kinds of network drivers work in DOS, and how to set them up
  • Packet drivers for a wide range of network adapters
  • ODI drivers for popular network adapters
  • IPX drivers
  • TCP/IP tools
  • The latest versions of Kali for DOS and Windows
  • A guide to host networking for 86Box on Linux using VDE, plus scripts to help set it up
  • Documentation available in both HTML and DOS compatible TXT formats!
Homepage: https://fo.ax/kali-kit/
GitHub: https://github.com/xfoa/kali-kit
Reply 1 of 2, by foax
I've put in some script and documentation fixes. See releases on GitHub for the latest ISO!
Reply 2 of 2, by foax
Updated with a license generator for v1.4a!
(Given the author has made available a license generator for later versions, I'm assuming he'd be fine with the same for the abandoned DOS version.)
