Just added a link to my post on the EGA/(S)VGA SLR behaviour, as well as some discoveries about it's latching and wrapping behaviour during the different graphics modes.
Ofc I don't think that the SLR bit would have any effect in text modes? Since there's nothing extra to rotate in text mode, I guess it would cause the same effect as 256-color mode shifting (the same pixels repeating over and over due to the same inputs being used)?
Edit: Just improved the Tseng chips to properly use the EGA emulation bit to perform the horizontal and vertical blank end properly (masking to 5 bits instead of 6 and 8 bits respectively).
Edit: Just improved the shift registers to operate in big-endian mode properly on little-endian machines, since plane 0=byte 0 of the value read from VRAM.
Input Status 0 register: bits 5-6 are binary numbers from the feature connector. Their inputs for either FC0 set (lower bits) and FC1 set (higher bits)
Input status 1 register: bit 1 indicates light pen trigger set. bit 2 indicates light pen switch is open (not pressed?). Bits 4-5 report video status MUX (see color plane enable register) on EGA, required to POST.
1video_probe_CGA_or_EGA proc near 2 push ax 3 push cx 4 push dx 5 mov dx, IO_Port_3DAh_CRTC_Status 6 xor al, al 7 out dx, al ; Video: bits 0-1 control 8 ; Feature Control outputs FC0 and FC1 9 in al, dx ; Video status bits: 10 ; 0: retrace. 1=display is in vert or horiz retrace. 11 ; 1: 1=light pen is triggered; 0=armed 12 ; 2: 1=light pen switch is open; 0=closed 13 ; 3: 1=vertical sync pulse is occurring. 14 mov cl, 3 15 shr al, cl 16 and al, 00000110b 17 mov ch, al 18 xor al, 00000010b 19 out dx, al ; Video: bits 0-1 control 20 ; Feature Control outputs FC0 and FC1 21 push dx 22 pop dx 23 in al, dx ; Video status bits: 24 ; 0: retrace. 1=display is in vert or horiz retrace. 25 ; 1: 1=light pen is triggered; 0=armed 26 ; 2: 1=light pen switch is open; 0=closed 27 ; 3: 1=vertical sync pulse is occurring. 28 shr al, cl 29 and al, 00000110b 30 xor al, 00000010b 31 out dx, al ; Video: bits 0-1 control 32 ; Feature Control outputs FC0 and FC1 33 xor al, ch 34 cmp al, ch 35 mov al, 0 36 jnz short end 37 or ch, 21h 38 mov al, cs:39h 39 40end: 41 out dx, al ; Video: bits 0-1 control 42 ; Feature Control outputs FC0 and FC1 43 mov cs:39h, al 44 mov cs:46h, ch 45 pop dx 46 pop cx 47 pop ax 48 retn 49video_probe_CGA_or_EGA endp
EDIT: or are status 1 register Bits 4-5 reflecting FC0 FC1 only on CGA? then this function would make perfect sense, would only write to cs:39h cs:46h on CGA card.
