Reply 20 of 36, by tehsiggi
- Oldbie
maxtherabbit wrote on Yesterday, 12:49:Would you say the same thing about the ECS K7S5A? https://theretroweb.com/motherboard/image/1ds … b9950295964.jpg It has a visua […]
shevalier wrote on Yesterday, 09:45:it's a piece of the not_cake, sorry. https://theretroweb.com/motherboard/image/dsc-8840-647-6889454f92782530065577.jpg This moth […]
ChrisK wrote on 2026-05-11, 15:34:I have a K7SEM board which
This motherboard has a single-phase VRM with diodes in the lower branch instead of MOSFETs, and a PWM controller from an ATX power supply unit (KA7500b).
And the Barton is rated for around 60 watts of power consumption.
You’re a very risk-taking sort of person.Would you say the same thing about the ECS K7S5A?
It has a visually similar VRM layout but tbh I don't really understand power circuit design.
Same same - KA7500. Here three parallel FET (incl. push/pull transistor driver) + diode + inductor stages - all driven by the KA7500 which is a single phase switching regulator controller.
