Orpheus II soundcard thread *** LT board now available ***
Reply 1280 of 1298, by keropi
zb10948 wrote on 2025-05-18, 16:05:
Same as in first picture on Orph2 LT homepage.
could it be a simple connection issue? try to wiggle the jack around
is the midi cable a known working one?
also remember that the midi jack should go to the MIDI-IN port of your midi device
Reply 1281 of 1298, by andrean
Could we get another batch of the Morpheus II cards?
Reply 1282 of 1298, by keropi
andrean wrote on 2025-07-29, 05:36:
I have seen the message on the contact form as well but for now there are no plans to make more Orpheus 2 cards, all effort and time goes to the Xtreme card atm
Reply 1283 of 1298, by Kordanor
I am wondering if there is any way to change the sterio channels via the driver.
I looked into Ophinit as well as Unisound and couldnt find any.
Why would I want to do that? Well, I just wanted to play Dungeon Master 2, and apparently that game has swapped stereo channels (I can confirm that in other games they are correct).
Did I miss anything there? Or isn't there a way to swap it and I would need to use a hardware solution (or for recordings - fix it on the recording device)
Reply 1284 of 1298, by keropi
there is no option to do this via any driver available - crystal or 3rd party
I assume the game does not have a swap stereo option? the easiest way is to just swap the recording channels on post-processing
Reply 1285 of 1298, by Kordanor
keropi wrote on 2026-01-09, 14:07:
Alright, thank you!
There is no option in the game. But I will use a program called "Pedalboard" then to just swap them before recording.
Btw: I also checked to determine whether it's Orpheus Specific.
A friend tested with his ESS card (with Pro settings) and it's also swapped.
Also I do have a SB16 and another friend tested a SB AWE64 for me, and they are both broken in the game. As the game (which was released 1995!!!) does not properly support them (Sound not working on SB16 setting, and sounds bad and mono only on SB Pro setting).
So...the Sound processing of that game is a total mess. It's advertising spectacular directional Sound on the box. But... SB1 doesnt support it, on SB Pro it's swapped, and on SB 16 (released 1992) and everything newer it's completely broken. ^^
Reply 1286 of 1298, by sofakng
Can somebody help me understand the IRQs, DMAs, and environment variables?
Here is the summary from my orphinit configuration:
* Ctrl (Crystal) - 538
* WSS - 534 / IRQ 5 / DMA 1
* SB - 220 / IRQ 5 / DMA 1
* OPL3 - 388
* Gameport - 200
ORPHINIT sets the environment variable ULTRA16 to 534,1,5,0.
What is the purpose of this? It seems to relate to GUS Max SB emulation. If I understand correctly, it’s telling GUS software that uses SB emulation to use the Orpheus 2 CS4237 chip in WSS mode? However, if I want to use WSS then why wouldn’t I just select WSS in the game options (if available) ?
ULTRASND.BAT sets the ULTRASND variable to 240,7,7,7,7.
If I understand correctly, this tells it to use 240h, IRQ 7, and DMA 7. Is this correct?
Therefore, to enable all features of the Orpheus 2, I need IRQ 5 (WSS/SB), IRQ 7 (GUS), DMA 1 (WSS/SB), and DMA 7 (GUS) ? (two IRQs and two DMAs)
EDIT: It looks like I also need IRQ 2 (or 9?) available for MPU-401 intelligent mode. (I can’t disable 2 on my motherboard so I think I need 9?)
Reply 1287 of 1298, by Shponglefan
sofakng wrote on 2026-04-14, 17:08:
You're correct that you need an IRQ/DMA for each of the SB/WSS and GUS PnP options. And an IRQ if you want to use the MPU-401 interface with games that require an interrupt.
The Orpheus II is basically three sound cards in one which is why it needs so many hardware resources.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1288 of 1298, by sofakng
Thanks very much. Do I understand the IRQ/DMA usage correctly as well?
Reply 1289 of 1298, by Shponglefan
sofakng wrote on 2026-04-14, 17:51:
Yes. Assuming those hardware resources are available, you should be able to assign them.
Depending on the system you are using with the Orpheus II, you might need to reserve them in BIOS.
Reply 1290 of 1298, by 640K!enough
This actually has nothing to do with Sound Blaster emulation of any kind. It is used by some DOS software to determine the appropriate resources for a native-mode WSS-compatible CODEC, so that it can be used to provide up to 16-bit, 48 kHz stereo playback. This is usually for cards that lack the configuration interface of the original Microsoft-branded WSS board, and was originally introduced for the UltraSound MAX and 16-bit playback daughterboard of the original UltraSound (hence the name ULTRA16).
For instance, configuring Cubic Player to use the GUS 16-bit daughterboard will allow high-quality playback on Orpheus (all versions), using this environment variable to find the hardware. Similarly, Impulse Tracker will do the same when using my modified driver for any WSS-compatible hardware for which the resources are specified by the ULTRA16 environment variable.
It is interesting that some WSS-compatible CODECs can provide playback at up to 64 kHz sample rates. The CS4237B does not, but most designs based on the InterWave will do this via their CODEC module (but at a non-standard I/O port), as well as some designs based on the CS4231.
Reply 1291 of 1298, by keropi
the legend is back! 🤣
Due to popular demand OrpheusII pre-orders are now open! head over to pcmidi.eu for the details if you are interested 😀
Reply 1292 of 1298, by Kordanor
Oh, cool! Only the "Full" version though? Not the LT one?
Reply 1295 of 1298, by appiah4
@keropi when will you be shipping the cards? There is only a specific window of opportunity for me to receive the card.. I would love to be able to get one, but the logistics are pretty terrible thanks to fucked up customs 🙁
Reply 1296 of 1298, by keropi
appiah4 wrote on Today, 07:06:
the plan is to order the boards June 1st and start shipping a month or so later...
one would imagine one country over would be a simple matter but these customs do have sticky hands no matter where you are... :\
Reply 1297 of 1298, by Duffman
Red PCB or Green?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 1298 of 1298, by Marmes
Green. Red was a limited edition.
