Reply 5160 of 5230, by TechieDude
Law212 wrote on 2026-04-29, 19:07:
Are you finding a lot of stuff in Greece? My dad took a bunch of old computers to Greece in the 80s to a school in our village of Visinia so the kids could learn english. When I was there last I didnt think to check the school if they were still there. I wonder if they are.
Yes, but nothing that old. I typically find early 90s to late 2000s stuff, but even that has also started to move forward. I also live in Athens, so I have no clue what happens in other areas.
Reply 5161 of 5230, by CrFr
Found this in the trash today. Not really computer hardware, but you could connect it to a computer with serial cable for some retro navigation software experience (if I had a serial cable). Cool device, works and finds satellites just fine.
The attachment IMG_1878.jpg is no longer available
Reply 5162 of 5230, by rasz_pl
CrFr wrote on 2026-05-12, 18:43:
Magellan GPS
Surprised pikachu face 😮 I would expect with week number rollover (10 bits = ~20 years max) old GPS receivers to no longer function correctly, or even refuse to boot.
Reply 5163 of 5230, by CrFr
It took a long time to acquire the position on first start. I waited for something like 5-10 minutes and still nothing. At that point I thought it was not going to work. I left it outside and went to do something else. After 15-20 minutes when I came back to check, it had found the satellites. Coordinates match with iPhone GPS. I walked around a bit with it, and it displayed speed and track. On next power-on it was a lot faster to start.
I find it impressive, that a device from 1998 still works with modern day satellites.
Reply 5164 of 5230, by rasz_pl
CrFr wrote on 2026-05-13, 09:06:
so it has 1-2 years of life left, or until internal battery dies and it forgets current date, after that its game over
Reply 5165 of 5230, by douglar
Is it all ASIC or does it have a general purpose CPU like a Z80?
Reply 5166 of 5230, by CrFr
douglar wrote on 2026-05-14, 17:12:
I highly doubt it has any general purpose CPU. It runs on four AA batteries and gives estimated runtime of 30 hours on those. It has to be some kind of ASIC for that efficiency. Sure, I was tempted to open the case to see what kind of hardware it has, but the device is weatherproof. After opening it might become less weatherproof 😁
Reply 5167 of 5230, by douglar
CrFr wrote on 2026-05-14, 17:30:
Because with that D-pad on the thing, maybe you could get it to play Tetris
The attachment s-l960.webp is no longer available
Reply 5168 of 5230, by EvieSigma
The E-waste bins at work typically only have crap LCD monitors, peripherals, and broken laser printers. So when some stuff that very much ISN'T that got dumped today, I grabbed as much as I could!
The attachment PXL_20260514_210552915.jpg is no longer available
The attachment PXL_20260514_210627521.jpg is no longer available
Reply 5169 of 5230, by douglar
EvieSigma wrote on 2026-05-14, 21:40:
I love that style of ~1994 AT case. Those were by favorite. Looks just like my 486-100 VLB system.
What's inside?
Reply 5170 of 5230, by Boohyaka
Yeah the case is cool, but scoring not one but two CRTs, now that's epic and always make a haul special! 😁
Reply 5171 of 5230, by orcish75
Bonus points if you get Doom running on it!
Reply 5172 of 5230, by EvieSigma
douglar wrote on 2026-05-15, 01:24:
What's inside?
An extremely good motherboard, turns out...
The attachment PXL_20260515_224702636.jpg is no longer available
The attachment PXL_20260515_224706396.jpg is no longer available
Haven't figured out the CPU yet but I imagine it's probably a K6 or K6-2.
Reply 5173 of 5230, by BitWrangler
Oh yes, you have won the pot of jacking... umm jackpot.
Reply 5174 of 5230, by SiBurning
Is there a Dumpster FILL thread?
I decided to pop open my PS (piece of...) and it needs unobtanium caps. I will NOT desolder and resolder an Antex 303, though my Hakko FM-204 would make short work of it. Will order one off the dock of the bay instead. If that one needs work... has anyone turned one of these into a modular design? Meanwhile the mother ... board ... could use new caps.
Reading around vogons a bit... It might be easier to make a daughter board or breakout box, plugging the PS into one side and adding connectors to the other ... But offhand, ... why do I suspect this is a waste of time?
Reply 5175 of 5230, by douglar
BitWrangler wrote on 2026-05-15, 23:40:
That looks like a legit ATi Rage IIc !! (joking) Those Ali ALADDiN V boards are pretty rare these days. Nice find.
Reply 5176 of 5230, by Ozzuneoj
EvieSigma wrote on 2026-05-15, 23:11:
An extremely good motherboard, turns out... […]
What's inside?
Nice! Those are great boards. Looks like the PSU was replaced with an Antec much more recently.
Also, I can't remember the last time I saw a system from this era with an ISA card long enough to actually utilize the slots at the front of the case. That's pretty neat. 😁
Reply 5177 of 5230, by jmarsh
rasz_pl wrote on 2026-05-13, 09:41:
GPS units get the time from the satellites, they have no reason to have a calendar/RTC.
Reply 5178 of 5230, by CrFr
Also, this unit has already gone through two week number rollovers, in 1999 and in 2019. Next one is 2038. I don't understand why it would be different next time to brick it. Failing battery is not a problem since it uses normal AAs. I don't see any reason why it would stop functioning in the near future.
https://www.gps.gov/news/gps-week-number-rollover
Reply 5179 of 5230, by EvieSigma
douglar wrote on 2026-05-16, 02:39:
I have the ATX version in another system, did not expect to luck into the AT version too.
