First post, by Socket3
Hey guys. It's been a while since I posted.
I got a hold of 3 ATI Rage 128 GL PCI MAC cards, with part number "109-57400-00" and BIOS label "R128 57407"
The attachment 128pci.jpeg is no longer available
and another 3 Rage 128 PRO AGP MAC cards, part number "109-63000-00", BIOS label "P128P 63001"
The attachment 128agp.jpeg is no longer available
I have no use for these in my apple PCs. All my G4's came with either an AGP rage 128 identical to these or better cards, and I have no G3s (or any interest in getting any, except for maybe an All in One G3) so I'd like to flash these so they'll work in a PC. I've read the threads here on vogos, and tried 5 video bioses on the PCI cards and 2 on the AGP ones, with no success.
The closest I've gotten is by flashing vbios file BK1.0.13 from https://theretroweb.com/expansioncards/s/ati-rage-128-gl-pci, witch seems to be from an All In Wonder PCI. This lets me install the corresponding driver in win98 when the 128 pci is set as a secondary card, but there is no video output on the monitor. It shows "out of range" or simply a black screen. Trying to boot the PC with only the flashed rage 128 also gets me an "out of range" message, but the PC boots up fine and loads windows (i can hear the startup chime in the speakers).
The BK1.0.12 file is from an Xpert 128, but I think it's from an AGP card. ATIFlash will flash it if I force it to, just like with BK1.0.13, the ASIC numbers match, but the part numbers don't (57403).
Has anyone been successful in flashing a PC bios onto one of these??? I could really use 3 PCI pc cards with 3d acceleration, and they're just sitting there gathering dust..
Does anyone have a PC rage 128 GL with the exact same layout? Or a bios for part number 57407 so I can use these on PC?
What about the AGP cards? i've flashed two video bioses so far, ATIFLASH did it's job without complaints, no need to force flash like with the PCI cards, but no luck. The card will not post.
Reply 1 of 36, by Socket3
[UPDATE]
I've had limited success with the AGP versions. Apparently they are also Rage 128 GL variants, but with 16MB of ram over a 128bit bus. I've managed to flash a bios file from VGAMUSEUM MKIII from a 16MB 128GL AGP card and the MAC card I flashed now posts. The DVI port does not work, and only 8 out of the 16MB of vram is detected, and only at 64 bits. The ASIC number is different for the BIOS I flashed as well.
So basically the AGP cards need a video bios from an SDRAM card with 16MB over 128bit.... all the SDRAM Rage 128 GL PC cards in my collection are 64 bit...
The attachment succ.jpeg is no longer available
As you can see the card posted and installed as an Xpert 2000 under windows XP. It ran quake 2 with the default XP driver, scoring 29.8 FPS at 640x480.
Anyone own a rage 128 GL AGP with 8 memory chips?
Is there a way to modify the existing bios files or the stock roms?
Reply 2 of 36, by marxveix
Win9x and Rage3 gets more Quake2 640x480 fps than Rage128 (Rage4) in XP. I dont know whats good OpenGL for XP, but for Win9x and Rage128 (use OpenGL 1274).
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 3 of 36, by Socket3
marxveix wrote on 2026-05-13, 07:11:
Yeah it's pretty slow. Almost Voodoo 1 slow...
On topic - I figured out what the problem is - the cards are 16MB / 128 bit. All of them, PCI or AGP... The PCI cards will not output an image with the All in Wonder Rage 128GL bios, but they are detected correctly. The bios reports 32MB despite the card having only 16MB.
The AGP cards work with the 16MB bios, but that bios is taken from a 64 bit card, and only half the ram is detected... somehow.
Is there a bios editor for ATI cards that suport the Rage4? Something like nibitor is for nvidia... I'm wondering if I can mod the bios files I have to get these cards working.
Reply 4 of 36, by marxveix
Socket3 wrote on 2026-05-13, 18:07:
For Radeon sure is, Rage cards have some flashing tools, but editor for Rage3 i have not seen, for Rage128 maybe.
Something is here (for mac<->pc and rage128 crossflash):
https://disk.yandex.com/d/vfgML2Vm3TR4mw/-BIOS/Ati_RAGE_128
https://docviewer.yandex.com/view/0/?*=AuHL3W … Tc3MTQ1Mzk4OSJ9
Reply 5 of 36, by Socket3
marxveix wrote on 2026-05-13, 19:12:
For Radeon sure is, Rage cards have some flashing tools, but editor for Rage3 i have not seen, for Rage128 maybe. […]
Thank you. I don't understand what the author of the text file is trying to say - using a translator yields sentences that make little sense, but I'll try the files included in the archive.
My cards are 16MB 128 bit, hopefully those BIOS files are for 16Mb cards as well.
Reply 6 of 36, by Socket3
Unfortunately none of those BIOS files in the mac to PC page worked for me, neither for the AGP or the PCI card. For starters most files are the wrong size, another that is the right size and ASIC type is corrupted (checksum error). The rest do not work.
I have made more progress with the AGP cards - I've been able to find a 16MB BIOS file that makes the AGP version PC compatible. I've even tested in Quake 2 3.24 @ 800x400 with a 550Mhz pentium 3 it gets 40 fps. The Bios is clocked 112Mhz for both ram and core.
Here is the file that worked for me in case anyone else wants to flash the AGP 16MB 128bit Rage 128 GL to PC:
The attachment 16mb-agp.rom.zip is no longer available
This file also makes the PCI version post, but it will display a black screen. It's detected in windows and the driver installs fine when used as a secondary card, but when enabling it it still gives a black screen at any resolution.
I'm still hoping to get the PCI cards to work on PC. Does ANYONE have a PCI Rage 128 with this layout?
What utility could I use to edit Rage128 / Rage4 bios files?
Reply 7 of 36, by Socket3
[UPDATE]
I read the MAC PCI Rage 128 GL has a 128kb flash rom... the BIOS files for the PC versions are 32 or 64 kb in size.. Is it possible ATIFLASH 1.6 isn't correctly flashing / completly flashing the EEPROMs on the MAC PCI cards, causing it to not read correctly at POST?
If that's the case, desoldering the 128kb EEPROM and soldering one a 64 or 32kb module form a pc rage 128 card then flashing the Xpert 2000 or generic PCI Rage 128GL ROM might work, right? I have a few parts cards, I could try this approach. Another way might be creating a custom 128kb rom file that has only the first 32kb of data and the rest all ffffffff or 00000000 might also work.
I'll try and post my results.
Reply 8 of 36, by marxveix
Rage3 ATiflash works only up to v1.5, cant remember what was best from 1.0 to 1.5, v1.6 did not work for older cards.
Here older ones and 1.6 also here.
Old ATIFlash utilities
Reply 9 of 36, by Socket3
marxveix wrote on 2026-05-17, 09:08:
1.6 worked fine for me so far, but thank you for the link!
I've made further progress:
- I've taken the EEPROM (AMTEL AM49F512) from a very low end looking OEM Rage 128:
The attachment donor.jpeg is no longer available
-Soldered the donor EEPROM to the MAC Rage 128 PCI:
The attachment cards.jpeg is no longer available
LEFT - modded card with 64kb EEPROM ----- RIGHT - unmodified MAC Rage 128
- Flashed all the PCI EEPROMs I have gathered so far, witch is only 3 roms...
- The card posts only with the All In Wonder Rage128 rom taken from TheRetroWeb - this file:
The attachment bk1012.rom.zip is no longer available
but there is a catch.... My LCD monitor reports "non standard settings" message. I think the card is outputting 61hz, but have no way to make sure. I'll hook it up to a smarter display and check. Then it got worse. In Quake 2, the card set some refresh rate that my LCD did not support. When the LCD went "out of range" I hooked it up to my 21" IBM CRT and that displayed just fine, and it didn't complain about the refresh rate. I fixed this by capping all resolutions to 60hz with Rage128 tweaker. The card installed fine under win98 with the rage128 drivers I had on hand as an 'All in Wonder Rage 128". I think the drivers I'm using are from 2002, I got them from a thread on this forum. I also installed rage128 tweaker. One issue is that several AIW devices show up in control panel:
The attachment devices.jpeg is no longer available
I disabled the devices of course, since this is not a real All In Wonder card so there's no TV tuner.
It runs Quake and Quake 2 just fine. problem is it tries to run 76hz or 81hz out of the box, so my LCD will go nuts when running quake 2. Works fine in GLQuake.
The attachment quake2.jpeg is no longer available
A good 100% conversion would require a rom from the PC version of this card. The rom on TheRetroWeb doesn't work, it's probably for a 32mb card, or it has some other issues.
I'm still looking for a tweaking utility or some way to edit the roms... gut the rom to remove the AIW parts so they won't show up in device manager, correct the display output frequency, and adjust the clocks. Right now the card runs at 92/92MHz.
Still, I got 1 of 3 PCI cards working on PC, and it's going right into my Pentium PRO rig.
Reply 10 of 36, by Socket3
[UPDATE!!!]
More success!!!
I found a BIOS that is perfectly compatible with the AGP MAC cards. They are 16MB Rage 128 PRO II 4X cards running at 118Mhz core and 143MHz ram. Memory is 7ns, 8x16 bit chips 128 bit. I used the Rage Fury Pro bios from my SGRAM card, flashed that over to one of the AGP mac cards, and it boots up and runs a treat. Clocks are 118/143Mhz. The cards will reliably do 125Mhz core, but not higher then that. They're very fast, only limited by the 16MB framebuffer.
This is the donor card:
The attachment fury.jpg is no longer available
https://theretroweb.com/expansioncards/s/ati- … -sgram-vivo-agp
Here is the BIOS I dumped from the Fury Rage PRO SGRAM with ATIFLASH 1.6. It was flahed with the same tool.
The attachment FURYSGR.zip is no longer available
I'd love it if a moderator would upload this BIOS file to TheRetroWeb so it can help others
All cards worked with the stock 128kb EEPROM.
There is one issue. Just like the PCI MAC card, the AGP card will output slightly higher refresh rates. Instead of 60hz it outputs 61. Instead of 85 it will output 86.2. This will cause some LCD screens to complain about non standard refresh rates, or fail to display altogether. This also means refresh rates over 85hz will not display correctly on some CRT monitors. I have no idea how to fix this. I don't think it's a BIOS issue.
Considerations:
As it turns out, the limiting factor for cross-flashing is not the amount of type of memory - it isn't even the chip itself (you can cross-flash 5024 to 5442 cards with some success), but the clock speeds, interface and board layout. Memory interface also matters. Flashing a bios from a 64 bit card onto a 128bit card seems to half the latter's amount of ram and memory interface. Another major factor is the flash process itself. I believe my failing to cross flash the PCI cards with a PC bios using the stock EEPROM is an issue with ATIFLASH and not the EEPROM itself. I can confirm this by installing a socket onto one of the cards and flashing a PC bios using a BIOS programmer, filling the extra ROM space with either all 0's, all f's or just doubling the ROM, witch is something I might do once I fix my programmer (USB port got damaged).
In any case, I'm very happy that I can use these cards in other projects. I as said above, I don't need them on MACs. I have 3 G4's, one of each type. The oldest one (a Graphite) uses a 32MB Rage Fury PRO SGRAM card. The QuickSilver model has a Geforce 2 MX video card, and my mirrored drives G4 has a Radeon 9000 Pro.
Hopefully this thread helps others use these cards.
Reply 11 of 36, by PC Hoarder Patrol
Socket3 wrote on 2026-05-22, 18:05:
[UPDATE!!!] […]
[UPDATE!!!]
More success!!!
Considerations:
Good to see the progress you've made with this. I've a couple of cards (pictured) that I've been meaning to try with for a while now.
Based on an archived ATI BIOS p/n / product line / chip spec matrix I'd already figured my best bet with converting 57401 might be either 57402 or 57403 (BK1.0.12). This link seems to refer to 57401 / 57402, so we'll see if it helps in my case when I get round to it... https://bitsavers.org/pdf/ati/109-57402/
The attachment MAC R128GL.jpg is no longer available
NOTE: no idea what the patch wire is for!
Reply 12 of 36, by Babasha
Socket3 wrote on 2026-05-10, 17:00:
Hey guys. It's been a while since I posted. […]
Sometime ago i use ATTACHED flasher and ROMs to convert MAC ATI. Rage128GL PCI to PC conversion without any soldering
Need help? Begin with photo and model of your hardware 😉
Reply 13 of 36, by Socket3
Babasha wrote on 2026-05-25, 13:50:
Thanks for the ROMs! I take it flashing these will make the card work correctly? Because my solution besides the inconvenience of having to solder another ROM - outputs 61hz instead of 60.
Reply 14 of 36, by Thermalwrong
Socket3 wrote on 2026-05-26, 18:12:
I'm interested in this too since I've got one of those ATI Rage128GL PCI cards that I'd also like to use with a PC since I don't have any Macs that could use it. Thanks to both of you for starting this topic and sharing PC ROMs that could work.
Have you considered that it could be a clock crystal or PLL difference? The PC cards have a 14.318MHz crystal and the mac cards all appear to have a 29.498928MHz crystal - dividing that by 2 gives around 14.75MHz and that's about 3% different from the PC crystal, perhaps that ratio of difference is causing all frequencies output by the card to go up by 3% or so. Might be worth checking with an oscilloscope to see what frequency the VSYNC is outputting at different display frequencies.
Or just put a 14.318mhz crystal on and see what happens 😁
Reply 15 of 36, by Babasha
Never get any incompatibility - i just flash my Mac R128 PCI ftom G4 or G3 Macs and install generic W9x drivers
Reply 16 of 36, by Yoghoo
Babasha wrote on 2026-05-26, 18:58:
I just flashed it but my testbench LCD screen does not like it during booting and in DOS (out of range error). So only a black screen. It works in Windows 98SE when correcting the refresh rate in the settings (60 or 75 MHz depending of the resolution). Unfortunately can't use it in this state as I can't even change/see the BIOS settings when booting.
Reply 17 of 36, by Socket3
Yoghoo wrote on 2026-05-31, 16:57:
I had the exact same experience. You might get a picture on some CRT monitors but most LCDs will complain.
I'm planning to try and replace the crystal on one of my cards with the crystal off an AGP PC card see what that does. I'll post results here.
Reply 18 of 36, by moflihmoflih
hi guys
i think that i have solved the issue
short answer is : wrong "Dot Clock Reference Frequency" in the PCI roms which is = 28.6Mhz, while on the crystal onboard is 29.498Mhz 😀
find the 29Mhz moded rom here
https://drive.google.com/file/d/139u2tTwWMtxC … iew?usp=sharing
2 weeks of scouring the ATI RAGE 128 programmer reference guide, and disassembling the ROM (found PLL tables, bios header values.....) i was looking for why my (MAC to PC) card was showing 16MB instead of 32MB well later i discovered that the VBIOS is universal and that it tests all configuration starting from 32MB down to 4MB, and that my card is indeed a 16MB 😁 (didnt pay attention to rams installed i just followed what the net was saying).
anyway with the RAM size problem solved now i started tackling the "Signal Error" on LCDs and high end CRTs of this converted card
The attachment outofsync.JPG is no longer available
so while looking for a solution on the net i stumbled on this post, so you were just like me having the same issue, i kept reading until "Thermalwrong" gave the right suggestion the one clue that i needed
which is the "crytsal frequency" might not match!
so i quickly jumped to the disassembled code and in the PLL table i found:
The attachment dot clock freq.jpg is no longer available
and right there the frequency was 28.6Mhz and not 29.4Mhz !
so i changed the offsets as follows:
2948 -> 0B84h
0992h 30h -> 84h
0993h 0Bh -> 0Bh (unchanged)
NOTE: these offsets are not the same on all ROMs, you need to calculate these starting from header bios pointer which is at offset 0048h if someone is interested i will do a post on this dissassembly.
then i used the ATI bios editor by Alex Yakovlev to recalculate the Checksum (this ati rom uses a table checksum not a single byte checksum).
flashed it using ATI FLASH1.6 (it didnt work on my pentium 4 board but flashed fine on pentium 3 board )
The attachment DSC_1448.JPG is no longer available
and voila, now the out of sync problem is gone, forever .... well i need your feed back to make sure ...
The attachment DSC_1450.JPG is no longer available
note: (the moded rom goes from 64kb to 45KB which is due the ATI bios editor, but its the only way i found to correct the checksum)
Enjoy!
Reply 19 of 36, by Yoghoo
moflihmoflih wrote on 2026-08-11, 14:07:
hi guys i think that i have solved the issue short answer is : wrong "Dot Clock Reference Frequency" in the PCI roms which is = […]
hi guys
2948 -> 0B84h
0992h 30h -> 84h
Enjoy!
Nice find. Tried it on my card but unfortunately I didn't get any output. See attachment for the bios that was on the card before I flashed it.
