Need help for this system
Reply 20 of 22, by PcBytes
cydvog wrote on 2026-05-16, 21:59:
PcBytes wrote on 2026-05-16, 15:55:
Disable V-Sync. Geforces have it enabled by default in the most used driver version and they run slow unless turned off.
There is no vysnc option on nvidia control panel. Only on opengl not direct3d
Download the coolbits-forceware registry file from Phils' website:
https://www.philscomputerlab.com/nvidia-9x-gr … cs-drivers.html
It enables a lot more stuff, among which you can disable V-Sync for both.
Reply 21 of 22, by cydvog
PcBytes wrote on 2026-05-16, 23:06:
Download the coolbits-forceware registry file from Phils' website: https://www.philscomputerlab.com/nvidia-9x-gr … cs-drivers.ht […]
no diffrence at all. thanks for entry
Reply 22 of 22, by cydvog
BTW my board ga - 6bxc supports 1x 2x agp ports but my gpu is 4x ? Do maybe its the problem?
