First post, by Myloch
Hi men,
I've recently managed to get these rare animals in my collection: the first Uncle Albert trilogy by Emme / Lexis Numérique. It installs correctly but when you run game exe (chapp.exe), it does nothing. The game uses quicktime, macromedia director or something like that. A tool like OTVDM installed on your system is not helpful in this case. Any idea if a patch exists or some new dlls or similar?
Note: I know I can always use a virtual machine, but I want to find a different solution.
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 1 of 2, by BEEN_Nath_58
I recalled from my test 2 years back that the game would crash in waveOutGetNumDevs. Disabling the sound would let it work. I tested only Magical Album
Reply 2 of 2, by BEEN_Nath_58
As to what I understood, and following what crazyc said, the game is calling midiOutOpen() from inside DllMain, which is illegal because DllMain runs while Windows holds the loader lock.
midiOutOpen() internally touches COM/audio subsystems, and during cleanup it eventually calls CoUninitialize(). On modern Windows, COM detects that this is happening during DLL load/unload and intentionally crashes the process to avoid deadlocks.
Also it seems like bypassing midiOutOpen is enough. DxWnd has a Tweak/sound:midiOutOpenBypass that may be fit for this case
