First post, by rico001
After installing the game to the hard drive from the floppy drive got a resource.cfg file error. I think a solution that worked in real life to fix this was to go into the directory of the game on the hard-drive, thex2 not the sierra directory (but below it )and run install again from the hard drive. May re-verify later. Think I had to do this in real life before. The game also has information in included papers on how to format floppy disks and make backup copies in case of data loss. game used 720kb floppy disks
Reply 1 of 1, by TheMLGladiator
Are you able to upload the resource.cfg file here?
