First post, by batmreload
Did some digging around, and while i see there is a modified bios for
the CUBX, I was wondering if anyone has tried to cross-flash it with one from the CUBX-L motherboard.
Boards are Identical, except for the embedded CMD controller.
As I'm probably going to use a SIL 3114 controller, I'd like to disable it in such a way as to reclaim its IRQ.
From my knowledge, while its possible to "disable" certain devices on 440BX motherboards, the IRQ/Address doesn't get freed up.
Though I don't think I've ever used this particular board.
Thanks!
