First post, by JamesJoey123
Hi. When I try to run a bat file DosBox locks-up dead as a door nail. Ctrl-Alt-Del won't even bring up task manager.
Any help will be appreciated,
James
Reply 2 of 9, by JamesJoey123
@echo off
cd C:\LSL\LSL1VGA
lsl1vga
Reply 3 of 9, by wd
Rank DOSBox Author
DOSBox Author
you need a batch file for that? oh well
Reply 4 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
batchfile is broken
cd c:\lsl\ls1vga ...... <- that is wrong! (remove the c:\ )
This way you end up call the same batchfile over and over again
Water flows down the stream
Reply 5 of 9, by Flamin362
ok im new to dos box (see my post count) - love it by the way i've been looking for a way to play space quest on xp for ages
anyway
how can i make a batch file for opening a game with dos box
thank you for any help
Yay Space Quest on XP
Reply 6 of 9, by eL_PuSHeR
Creating batch files isn't difficult but I strongly advise you getting a front-end for DOSBox. It will make your life easier.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 7 of 9, by Flamin362
i have had a look at d-FEND reloaded but its gibberish to me
Reply 8 of 9, by wd
Rank DOSBox Author
DOSBox Author
Then use another frontend.
