First post, by ralphmaif
It started here...
The attachment Screenshot_20260427-201845.png is no longer available
I failed (miserably) at working with QFP 100pin de/soldering (a story for another beer) and had started looking for socketed 386DX boards and systems so I could scratch that itch of taking a 386 to a 486 like I did as a kid. This came up...
The attachment Screenshot_20260428-210534 (1).png is no longer available
Mitsubishi MP 386s. It's an Intel 80386sx-16 with an Intel FPU, 1MB (or is it 2MB?) onboard RAM, and no hard drive or video controller despite a floppy controller and plenty of ports (AT keyboard, 2x db9 serial, and parallel). This one arrived at my house with an ISA IDE card, an ATI LMS audio card, a WSS sound card, yet no video card. I couldn't find much detail on it other than there were some proprietary parts which do end up limiting its capabilities when unavailable.
But a socket is a socket.
The attachment PXL_20260517_165332770-1.jpg is no longer available
The TI486SXLC2 G50 WN is technically 3.3v but 5v tolerant. My crap desoldering was able to facilitate swapping the 32MHz crystal with an oscillator socket for which I've tried both 40 and 50MHz crystals. I also replaced the Intel 80387 with a Cyrix FasMath.
The challenge is this...
The attachment PXL_20260506_032908130.MP.jpg is no longer available
I think this is the header for a proprietary RAM module that is basically unobtanium now. Worse yet, that's your only path to 32bit memory upgrades as there are no slots of any spec on this board. I picked up an Acculogic RAMpAT! Plus which, even loaded up with 16MB 60ns of parity memory, doesn't compete when choked on an ISA bus.
But I'm having fun. I got a Powergraph x24 1MB board, a Sound Blaster 32 CT3600, slid a 32x CD drive where the 5.25" floppy was, hung a 2GB CF card off the controller, and boot to DOS 6.22, courtesy XT IDE ROM on the 3c509b.
Games like Tie Fighter and Doom, of course, run like ass when trying to hammer extended memory, but Wing Commander 1 and 2 are brilliant.
The attachment PXL_20260520_000143138.jpg is no longer available
I still need to sort out issues like the RAMpAT's dead battery, dialing in the best Cyrix utility for L1 cache and clock doubling, and dealing with the checksum error on the CMOS. That last one is a head scratcher. I replaced the battery, so the date/time memory works, but there's an error at boot up and no native way to get into the BIOS at POST. I found a couple generic Phoenix utilities that run from DOS to allow some editing, but neither clear the error.
Will keep searching and will post more photos later. It's really a nicely constructed beast.
Reply 1 of 2, by BitWrangler
I don't think you get a 32bit memory upgrade in an SX class system. It would most likely be 16bit... however that would be at CPU bus speed, not ISA speed, so 3x faster or so.
Reply 2 of 2, by ralphmaif
Right, my bad, but yeah...the ISA kills DOS4GW.
Some more eye candy...
The attachment PXL_20260504_224506677.MP-1.jpg is no longer available
The attachment PXL_20260515_184023377-1.jpg is no longer available
The attachment PXL_20260516_235543274.jpg is no longer available
The attachment PXL_20260517_000114746.jpg is no longer available
The attachment PXL_20260519_233823116-1.jpg is no longer available
