IDE Drive detection
First post, by Aui
Hi everyone, I have a question regarding initializing a CD-Rom. The drive is connected to the IDE controller of a SB16 and initialized with
"DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL" in the config sys and
"C:\DOS\MSCDEX.EXE /D:OPTICAL" in the autoexec.bat (all as per Phils Bootdisk)
the problem is that the drive NEVER gets initialized after a cold start (or reset)
The attachment 20260521_111950.jpg is no longer available
but ALWAYS works after a second soft reset
The attachment 20260521_112104.jpg is no longer available
Any ideas / suggestions ?
Thanks
Reply 1 of 5, by jakethompson1
Jumperless/ISAPNP cards will de-configure themselves on reset. If your sound card is assigned its resources via a config.sys driver, put videide.sys after that driver rather than before so that this reboot isn't required. If it's assigned its resources via a configuration program or TSR loaded in autoexec.bat (including unisound), you'll have to use a DEVLOAD or similar style utility to load videide.sys from autoexec.bat (before mscdex).
Also: using /D:OPTICAL means that you cannot access a file or directory with the name "optical" anywhere (hard drive or floppy included), this is why typical device names were along the lines of MSCD000
Reply 2 of 5, by Aui
Perfect - thanks a lot
Reply 3 of 5, by AncapDude
These device names are reserved words in all filesystems? Wow, didn't know that.
Reply 4 of 5, by konc
AncapDude wrote on 2026-05-22, 09:45:
What you specify as device name becomes a reserved device name just like CON, PRN etc, which means this name also cannot be used as a file or directory name.
Reply 5 of 5, by Aui
Well, I dont usually call any directories "optical" but who knows, so I changed it to MSCD000
