Tiido wrote on 2026-05-26, 17:07:
Most PSUs I have looked into have a 7905 without a heatsink on the -12V line to make the -5V rail, sometimes inside heatshrink to prevent shorting into chassis etc. ...
That does seem odd to me - not that it would work (I'm sure it would), but many supplies rate -5 at 500ma ... and I don't see how it could safely meet that spec without a heatsink.
These little 3-terminal regulators are typically rated at 1a ... and I just happen to have a good "stash" of 14v center-tapped transformers, so I make little PSUs to power my handbuilt projects all the time. Using a full-wave bridge rectifier, I get about +/-7<>8v from the ends of the bridge to the center tap (under load - it goes higher when unloaded)... perfect for RS-232, and using a 7805 on the +8 side gives regulated 5v to power the electronics.
But ... I find that drawing 0.5a (fairly typical) from it can get uncomfortably warn without a heatsink ...
8-5=3x0.5 = 1.5watts - This would probably be OK (but does get warm)
12-5=7x0.5 = 3.5watts - which I think would get too hot without something to dissipate it.
Granted - nothing's going to actually draw 0.5a - but that's what it's speced for!
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
