486 pc freezes randomly
First post, by markpot4
My 486 pc freezes especially when playing games and loading graphics. For example if in wolfenstein3d it freezes when loading a new picture and also it freezed when I scroll through the menu to fast with the keyboard.
I already testet the memory with memtrsr and it have no problems.
I also used scandisk to test the hdd also no problems there.
And also no cpu errors with checkit.
Also I realized when I turn off the internal cache the freezes occur more rare than with internal cache on. However underklocking the cpu with 35mhz instead of 50mhz make freezing worse.
What I also realize: when I turn the color depth higher in win95 the lcd monitor i use have some strange noise. But this could be also because a analog signal goes to a digital lcd monitor.
So my guess is: broken onboard graphics/vram, power suply, broken cpu, broken motherboard
What do you think is the problem here?
I have no other AT power suply, no isa vga graphics card or other 486 cpu at home to test and i dont want to buy all 3 things bc they are all very expensive. So I want to find out the problem to only buy oke of those to fix the problem.
Reply 1 of 2, by DaveDDS
Does this happen right after cold start?
Or after running a while?
If latter, could be dried thermal paste/cooling.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 2 of 2, by rasz_pl
Start by listing specs of the computer.
50mhz 486 could cause problems with VLB graphics
