First post, by aroneox
Decided to put together a rolling, continually updated thread for my new and current tech toys and their usage.
Early-2000's through mid-2010's seems to be the sweet spot for super cheap hardware to play around on. In my opinion, its also the peak of what we think of as "computing", where you could expect to customize and hack your hardware and software, before everything started getting locked down into an information appliance. So that's where I've been putting my vintage restoration efforts.
Starting out with few cool finds from that era:
file.php?mode=view&id=242745
First is this Core 2 Duo era MSI motherboard setup with a very era appropriate Zalman copper heat sink fan cooler. Specs are MSI P45-Neo2 LGA 775 mobo, Intel e8500 CPU and 16Gb RAM.
file.php?mode=view&id=242741
Next is a very unique circa 2001 Acorp 6A815EPD1 dual-socket 370 motherboard. Came outfitted with 2x Coppermine era Pentium III 1Ghz processors.
Picked this up at a roadside yard sale, along with a Pentium 4 era Dell Dimension 4500, which I grabbed for its parts, which include IDE CD/RW, IDE DVD, floppy drive, 512Mb (2x256) PC-133 RAM, and a surprise video card.
file.php?mode=view&id=242743
Potential plans are to build a workstation around the dual-cpu ACorp, set up in RAID configuration with Corel Linux as the OS and install the Linux versions of CorelDraw, Corel PhotoPaint, and WordPerfect Office.
Also possibly dual boot into BeOS as well for extra multi processor goodness.
Not sure if it’s even functional, as it looks like the machine was kept in some damp conditions with the case frame being rusted.
file.php?mode=view&id=242742
Inside the Dell Dimension parts machine was one of my absolutely favorite video cards: The Matrox Millennium G450 featuring dual display support and two separate VGA outputs. This is THE perfect card to pair with the ACorp dual-PIII mobo. If everything goes well, this will be an ABSOLUTE BEAST of a workstation. At least for 2000/2001.
file.php?mode=view&id=242744
Reply 1 of 2, by PcBytes
Fairly sure the Dell is functional. Rust seems to have formed towards the front of the case, which at utmost worst would net non-working front USB.
Reply 2 of 2, by aroneox
PcBytes wrote on 2026-05-24, 20:45:
Probably should have captioned that shot of the rusty case. It's actually the case (or more accurately the case frame since all the panels and plastic are gone) that houses A-Corp Dual PIII motherboard.
And yes, the rust didn't seem to invade the actual motherboard. It's mostly localized to the outside.
The Dell 4500 is pretty clean considering it wasn't stored in the most optimal conditions. But it was on the second row of machines, whereas the A-Corp PIII was on the ground.
I'm not really a big Pentium 4 era guy. For me, it feels more of a (long) stop-gap between Pentium III and Core 2 era.
