Reply 20 of 42, by Sas
PD2JK wrote on 2026-05-22, 19:15:Can you test the card in some other system, a bit more modern one perhaps?
Because it could also be the mainboard lacking to supply enough juice on the AGP port. 440LX is first gen AGP, maybe the mainboards' design wasn't calculated for the more power hungry cards.Which mainboard exactly are we talking about?
Updated observation
3d mark 99 does run but only for 2 seconds into the graphical test then the system freezes.
Could it be a heat issue?
