40+ years of source code
Reply 20 of 45, by DaveDDS
It really depends on the speed of the system (CPU and disks) and what processing is beng done on the data (and how).
Not having interleave when you need it can obviously slow down operations. eg: reading all sectors from a 18 sector track.. if your proessing is so slow that you "miss" each next sector, then you have to wait for it to come round again... In this case, 18 revolutions instead of 1.
1 2 3 4 5 6 7 8 9 0 11 12 13 14 15 16 17 18
But... having interleave when you don't need it can also cause system slowdown, eg: Reading sequentually with and interleave of 3:
1 7 13 2 8 14 3 9 15 4 10 16 5 11 17 6 12 18 you will need 3 revolutions instead of 1.
Given that the possible penalty for not having interleave is so much worse than the penalty for "too much" interleave, traditionally makers would err on the "to much" side.
With "modern"(ie: 286+) systems and DMA data transfer to/from FDC, 1:1 interleave is almost always best. There is so much "time" in the gaps between sectors (and even more at the end of each track) that most systems can process the data and queue up the next access. Many more recent disks format use 1:1.
Double stepping is almost exclusively used to make 360k(40 track) disks usable in 1.2m(80 track) drives. Yes 80 track heads are thinner and lay down thinner tracks. For this reason I don't recommend writing 360k disks at all on a 1.2m drive. If you have to (ie: You want to send a disc to someone who only has a 360k drive) - bulk erase the disc first! That will get rid of any vestages of any existing tracks.
In practice, the track laid down by the thinner head overwrites most of any that were made with a fatter head that the domains seen by the head are much stronger and the edges with the old data just result in more "noise"... but the good track signal is still within the range of the detection electronics and the laster/thinner track reads normally and everything still works as it should - ON WELL ALLIGNED DRIVES! - If the reading drive is a bit misaligned, the noise from the edges can be effectively more pronounced and cause problems.
This can actually help when trying to recover a damaged 360k disk content - by reading in a 1.2m drive and intentionally misaligning slightly to read more of the track from an edge.
Tracks don't line up quite well enough for adjacent tracks to help (not to mention that various ID bits will differ), formatting 80 tracks before 40 would just create more noise... Best way to "recover" an disk thats been written at 80 tracks to 40 tracks is to bulk erase it!
Format under OS will guarantee that low-level format is exactly what the OS expects. Obviously you want to do a "full" format and not some kind of quick or recovery format.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 21 of 45, by aVd
I asked about these interleave details, because I see, that NFORMAT is using interleave 2 for 83 track, 21 sectors 3.5" diskettes (bigger non-standard format). Probably the 18+ sector count is the main reason for this. I'll keep in mind, that interleave different from 1 is only good for diskettes used in 8086/88 systems or for diskettes formatted with bigger non-standard formats.
DaveDDS wrote on 2026-05-26, 13:54:
Actually I was asking not for recovering, but for preparing a blank 40 track diskette previously formatted and used on 40 track only drive with a newer 80 track capable drive. But, yeah, it seems like bulk erasing before formatting is the safest way.
what comes around goes around
Reply 22 of 45, by DaveDDS
aVd wrote on 2026-05-26, 14:31:
Probably has more to do with reduced gaps between sectors and end of track.
Also remember than if the system is doing significant (ie: time consuming) processing as it reads each sector, Interleave can still help.
It really does depend on how the data is being used (and "modern" systems will usually cache sectors allowing them to take advantage of low-interleave even if the application does "take it's time") - none of this is simple always-obvious answers 😀
Like I said, better to err on the "too much" side.
Reply 23 of 45, by aVd
DaveDDS wrote on 2026-05-26, 22:37:
Yep. More sectors per track means narrower gaps between the sectors.
So, it seems like there's no universal formula for floppy disk sector arrangement which can guarantee the fastest reading on both "modern" (huh, even Linux abandoned the floppy drives support years ago 🙁 ) and very old machines. Probably for the standard formats a sector interleave value of 2 is a good compromise if the diskette is used in both 8086/88 and more "modern" systems. Back in time I read for some 3rd party tools, that arranges sectors and gaps in a custom patterns, so the relatively slowly moving heads will access them as fast as it is possible. Unfortunately I cant recall at least one name of such a DOS tool.
Тhat is an ambiguity and could be interpreted as "too much" compatibility at expense of speed, or "too much" speed optimizations at expense of compatibility 😉
Thank you very much for clarifying the details regarding the questions I had, Dave! I think, I can finally use all the features of your awesome DOS ImageDIsk with the proper settings for the standard DOS diskette formats.
Reply 24 of 45, by MarkDastedt
hi dave because i hope you understand it much better than me could you look at fascinating Plain DOS 2 Core Demo. and say if itsnot a virus or so `? it should be a dos multicore demo. many thanks!!!
Reply 26 of 45, by DaveDDS
MarkDastedt wrote on 2026-05-27, 08:42:
Looks interesting, not sure what compiler and assembler it's written using, and given that I don't have any multi-core bare DOS systems, don't want to put time into figuring any of that out. I don't think DosBox supports multi-core at all...
I recall my first experience with multi-core ... wwaaaaaayy back in the day before multi-core CPUs were all common, we built up a system using a mainboard that supported two physical CPUs (we called it the "Whopper" - War Games reference)
IIRC we got an edition of Unix running on it which properly supported multi-threads/cores.
I "played" with hardware multi-threads in DOS a bit - I did get a program working which showed off hom much this system could do ... but nothing really useful under DOS - DOS just didn't track resources used by multiple threads, you could launch a program which enabled the second CPU pointed at it's own memory and with both "threads" being careful not to "stomp" on each other you could indeed count running loops etc. to show there were two running and how much faster it could be than one.
But ... you better make sure the second CPU didn't try to invoke any system resources and was halted before terminating, otherwise it would keep running as DOS reloaded something else into it's memory space.
And there had been some ability to address multiple threads within DOS as TSRs could load and perform background activity based on various interrupts... but there was never any support for true multi-threads running simultaneously.
Fun times!
PS: I didn't see anything that stands out to me as malware, but I've not dug deeply into what exactly the source code is intended to do either...
It's very uncommon to see malware distributed as source code, and I suspect if a "bad guy" did that, he probably wouldn't put in obvious source comments describing how he was damaging your system environment - just guessing tho ... I have no personal experience with producing such a thing!
Reply 27 of 45, by DaveDDS
aVd wrote on 2026-05-27, 08:39:
So, it seems like there's no universal formula for floppy disk sector arrangement which can guarantee the fastest reading ...
Exactly - interleave is a compromise which should be "tuned" to a given system (incl software running) to get faster possible performance, or course since it can't change "on the fly" nobody does that and the best you can do is get "as close during most/common operations" as you can.
I've not tried on the various Linux system, but I do know that at least with Winblows - even though floppy hardware isn't there any more, it does still recognize usb floppy drives (I've not tried with Win11 though) - and even it it didn't, Virtual machines can provide direct low level access to USB and other hardware and are often used to boot older OS editions!
This doesn't really matter - by "Modern" I am referring to anything newer than DOS - pretty much any multi-threaded OS will perform caching as it shares hardware between the threads.
And... Don't forget hard drives! - Interleave is more important there as the disk spins (and sectors "come up") much faster!
To truly escape the effects-of/need-for interleave ... you need to go to something like an SSD - any sector you want can be addressed immediately, no waiting for it to "come round"!
Yep - that seems like a good choice. This was all more important with now-ancient machines back when they were in common use (PDP11, Nova etc.)
Processors and disks were noticeably slower - These were the kinds of media ImageDisk was originally designed to replicate.
Sounds like a good marketing point ... but not possible in practice. It really does depend on how much processing is done by the application accessing the disk - which the maker of a "3rd party tool" can't know for each customer... and the particular application being used can change on an ongoing basis. It really is a compromise you try to optimize for "typical" use cases.
"too much" interleave (which may cause an unneeded revolution or two) is generally better than not enough (which will generally cause extra revolutions matching the number of sectors on track.
Glad to help - Perhaps I should add a document to the distribution which explains all these details. It really can be hard to judge what to document about a system where you personally have a lot of experience (and hopefully knowledge) - then again, most people using IMD these days are involved in archival operations, already know probably more than I do, and I really dislike "cluttering" my distributions with unneeded "Stuff"...
Reply 28 of 45, by aVd
For hard drives low level formatting back in time I used those built-in HDD LLF BIOS options in old motherboards and I think those rely entirely on HDD's parameters set by the factory. In most recent years (at least 15 years back in time) I used some windows software tools from Maxtor (and similar HDD makers), but I'm not sure, if they perform a true low level format on modern mechanical hard drives. And this is another huge topic, which I will pass 😀 I know, that there are some very old commercial software tools, which can be used to manually set bad sector tables and other HDD parameters, but personally never had one or used one. I don't know it it is possible to get such a tool by "legal way" nowadays, since they are long time ago considered as abandonware. I have no idea, if there is some free DOS tool for HDD low level diagnostics, formatting and setting.
DaveDDS wrote on 2026-05-27, 10:53:
In other words - "better safe, than sorry". We agreed on interleave of 2 for older systems compatibility in standard DOS diskette formats, and this fits in "better (a little more) safe, than sorry" 😁
Actually this is a pretty good idea. You can add some brief explanations in IMD's documentation about those more "obscure" settings like sectors interleave. And this is not an "unneeded stuff", but more like kind of an additional details for the newer IMD users (like me) about what is possible to be achieved by using the tool and why it may be of use in some particular cases.
Reply 29 of 45, by DaveDDS
aVd wrote on 2026-05-27, 11:44:
Actually this is a pretty good idea. You can add some brief explanations in IMD's documentation about those more "obscure" settings like sectors interleave. ...
There is in fact a pretty good description in IMD.TXT of what Interleave is, why it exists and how it works. I don't know that I could improve on this much...
Other "obscure" things are also mentioned - if you have suggestions on specific things you'd like to see added, or how to improve the descriptions - I'm "all ears"
Keep in mind the non-system specific nature of ImageDisk ... I don't want to offer "setup suggestions" which would make it work better with one system/format over another!
Reply 30 of 45, by aVd
You are right. But this does not explain why in the settings menu we can set interleave value of 99 (I know it's a math, but I will not count 99:1 shifting for 8, 9, 15. 18, 21, 26 or 36 sectors 😁 ). Apologies for my stupid suggestion about skipping the reading of "unpopulated" space on the floppy disk, which may potentially contain some bad sectors. Until yesterday I didn't knew, that IMD works while not relying on any OS properties/functions.
Reply 31 of 45, by DaveDDS
aVd wrote on 2026-05-27, 13:10:
Look under IMD F1-Help -> "General Notes" -> "256 Tracks/Sectors?"
Reply 32 of 45, by aVd
I will try to guess without starting my yesterday's 5.25" floppy head alignment rig. The maximum possible values in IMD settings have some relation to "better to err on the too much side", right?
Another (stupid) question (yeah, I still didn't RTFM): Why these reading values on perfectly calibrated FDD heads to head alignment reference diskette tracks differ in their maximum values from 30 to 36 for 5.25" and 3.5" FDDs respectively? Are these values related to some "signal strength", due to different head's contact surface over the magnetic disk surface on these two different type FDDs or probably the strength of the writing magnetic field is different for different drives, so the track records are also with different strength?
Reply 33 of 45, by DaveDDS
Not quite sure what you're asking ... I'm guessing we've switched to the A)lignment/Test function
This is just a fairly basic way to perform low-level functions on a drive. I mainly use it while repairing drives.
When using old floppy drive a lot, you really need to perform alignment sometimes ... but most users don't have a proper alignment machine which reads signal levels coming from the heads on specifically manufactured "alignment discs" which have their tracks written with clearly identifiable patterns in the exact correct position for each track.
The PC FDC hardware cannot do this ... so IMD provides what it can (and it does seem to work fairly well)
You have to have a disc written with good alignment - I recommend a software distribution disk from a major manufacturer (who will have discs made on properly aligned bulk production machines),
next - one you format on a new drive, next - one you format on a drive you've never had trouble reading discs with. Basically the procedure will align a drive to closely match whatever drive the disk was written in.
Since I can't read actual signal levels, I count how many sectors on a track have an ID which correctly matches the actual track, and how many are read which don't match - these are the two number you see which can change.
To make things easier, I sound beep which gets higher the more matching sectors are read in each revolution.
To align a disk, move the head and listen for the highest pitch of the beep (you can confirm on the display that the number of "matching" sectors is the number of sectors on a track.
Then... find the limits (to each side) of the head position where the beep keep at that highest pitch .. and lock it down at the 1/2 way point (exactly between those limits)
Most drives don't have perfect alignment over their stepping range, which I why I advise to perform the alignment test at several points over the
stepping range and pick a position which gives the beat matching sector count over that range.
Reply 34 of 45, by aVd
I already wrote yesterday, that I made alignment to upper head (number 1) on an old 5.25" 1.2MB FDD by using IMD's head alignment function and I'm not asking how to align the FDD heads. I'm asking about those numbers, that are coming in columns while reading is done. So, the first column of numbers is for the read track number, the second column consists of constantly changing numbers in a repeated pattern and seems like it shows the currently or last read sector number, the third column (I'm asking for this one) is changing according to head (dis)alignment and has different maximum value for the different FDD types or even for different floppy disk format types. And if I'm not mistaken, the last column with numbers is always zero for the perfectly aligned head.
DaveDDS wrote on 2026-05-27, 16:13:
So, this is the answer to my question. But now I'm wondering why on 15 sector formatted 5.25" 1.2MB diskette the maximum value for one head is doubled to 30, and respectively for 18 sector formatted 3.5" 1.44MB diskette the number for one head is doubled to 36? Why not 15 and 18, since only one of the two heads (0 or 1) is shown as active?
Reply 35 of 45, by DaveDDS
aVd wrote on 2026-05-27, 16:38:
When I said with IMD you really need to "know what you are doing" - a big part of that is reading the IMD documents!
There is a pretty good description of InterLeave there...
There is also description of what the Align/test number are...
I don't think I want to continue taking up Vogons bandwidth and server space with message where I'm reading the documents to people.
If you have specific questions not answered there, please ask - but RTFM before asking!
To be honest I don't really recall these details (Do you know how long it has been since I wrote IMD)
In Align/Test - IMD is reading the disk fields as they pass under the head, I don't really want to dig back into the details of System34 floppy formatting - because it does work quite well as it is, and rediscovering these details wouldn't get me anything (except a lot of wasted time finding 20 year old books)
There are probably more low-level fields than sectors but I don't recall - I can tell you that the "changing" number is the actual sector IDs being read.
EDIT: I just looked in the code and remembered why - it's actually counting and doing two reads of the track ... I don't recall why exactly I chose to do this, but it does make some sense to increase reliability (Remember Alignment/test is a "work around" for things the PC floppy controller can't do) - it also "slows down" the rate at which track reports are coming out.
Reply 36 of 45, by aVd
I'll "waste some more bandwidth" one more time...
I've intended to commend you on the clever way you solved the problem of reading a "good signal" (while there is no signal involved at all) from the floppy disk tracks, but the unnecessarily aggressive style in the first part of your last post made me change my mind. You reap, what you sow 😉
Look, Dave, I know what I'm doing and I've done it successfully by using your tool, which I still think is the best one among similar free DOS tools out there. I just didn't knew how it works internally, and the best I could do to understand this was to ask someone who knows (not RTFM!). And I've expected the one who knows best to be you... Now it really seems like you've just pasted me parts from the "manual" without even trying to understand what I've exactly asked for. It is true, that my English is not really good, but I've seen much worse in this forum.
I'm glad, that at least you've refreshed your memory by looking at your ancient source code. Good luck with "not wasting the bandwidth" next time, when someone asks you questions politely and without any sign of aggressive attitude!
Reply 37 of 45, by DaveDDS
Too bad you feel that way - I was not trying to be "aggressive" - but I really think it's not unreasonable to ask people to read the documentation of a complex/tricky program before asking a lot of questions that are answered there. (and to be honest I don't see how someone can claim to know what they are doing with such a tool when they haven't consulted the document for that tool - sorry if that's too "aggressive" a statement)
And - I wasn't cutting/pasting from the document (I don't even have it on this system), I was actually trying answer your questions.
I originally wrote ImageDisk for my own use, and so many other classic system collectors expressed interest in it that I spent a *LOT* of time cleaning it up and documenting it to make it more usable by others - there is a lot of useful information there - that's also why IMD has fairly reasonable interactive help.
Btw - your English seems good enough that I didn't even notice that it wasn't your first language - but I have to let you know that the guy writing these replies is no more fluent in other languages then the guy who wrote the ImageDisk documents 😀
Reply 38 of 45, by aVd
Sorry, that I offended you with my silly questions. I'm not here for this.
aVd wrote on 2026-05-25, 20:56:
IMD is very nice and handy DOS tool, thank you! Yesterday I used it for head number 1 (the one "on the upper side") alignment of a old 5.25" diskette drive and it worked very well. I also made a couple of image-files for some very old diskettes...
As I mentioned, I wrote this three days ago. And it means: I know how to do a FDD heads calibration/alignment and I used your nice IMD tool as a "black box" tool and replacement for equipment, which I do not have at home (yes, I can't spent a ton of money on some professional oscilloscope just for my retro PC hobby). I can't use oscilloscope at home to setup a rig for FDD head calibration, but I found out, that your IMD tool may be used for the same job in pure software way (no electronic devices/tools involved, just an working PC). To me IMD really was a "black box", which doesn't mean "I don't know what I'm doing or how should do it", but it means, that I was not aware of all IMD options/settings and how his software works "under the hood" (or beyond the user interface). I usually just use the tools without much thinking of them or how they were made, or whatever. But IMD is a software, so some silly questions popped in my empty head.
I fully understand, that you also gave your best to make some detailed IMD "user manual", but for the details you gave me here I can't be sure just by reading some lines of text from just one file.
And I'm sorry for annoying you with my irrelevant and silly questions, but at the end I did manage to get a detailed understanding of everything I was interested in, for which I'm grateful. My questions and comments regarding your IMD software, its potential, its usage, the PC floppy disk formats, etc. end here for good.
Reply 39 of 45, by DaveDDS
--- I wrote this before seeing your last response - but I though it worth posting anyway just so you have a better idea of where I'm coming from
--- (due vision/dexterity problems now - I tend to write most of my longer responses offline !in a big font!)
Btw, regarding "aggressive" thoughts on reading manuals, I have to say that I developed this attitude as a means of self-preservation when I ran my software company.
DDS produced development tools for many (more than a dozen) microprocessor families "back in the day" - my products were fairly popular, got some good magazine reviews etc. - hence I shipped thousands of them every year!
And it's truly surprising how many people don't read the documentation at all!
And... wanted me (the only one in the company) to be sending email replies or on the phone with them pretty much all day - "reading" my manuals to them:
I put a lot of effort into documenting my software. To give you an idea, here are some stats on the content of the "Documents" directory for some of my products (These are all .TXT files)
Micro-C 8051 Dev Kit    8 files,   460,699 chars, 11,023 lines, 236 pages
Micro-C 6809 Dev Kit 7 files, 426,747 chars, 10,242 lines, 223 pages
Micro-C Super Dev Kit 20 files, 1,029,772 chars, 32,879 lines, 870 pages
Micro-C/PC 5 files, 585,214 chars, 16,881 lines, 411 pages
This became enough of a problem that I had "canned" messages I'd send telling people that the information they wanted was in my documents (which were included in the packages I shipped).
Please don't judge till you've lived it!
