Reply 580 of 599, by Sghettikus
Thanks
Reply 581 of 599, by Sghettikus
ok so it only works when i have an actual burned cd in and not an iso
Reply 582 of 599, by myne
Eh?
Weird. I haven't even had a drive in 20 years.
I used daemon tools.
I built:
Reply 583 of 599, by BEEN_Nath_58
myne wrote on 2026-05-09, 13:27:
Eh?
Maybe they have drive letter issue? real drive letter is queried first
Reply 584 of 599, by Sghettikus
I use power iso so maybe that's the issue and the CD drive letter it's looking for is f
Reply 585 of 599, by BEEN_Nath_58
Sghettikus wrote on 2026-05-09, 13:57:
If you have both drive and power iso drive at the same time, one thing you could do is swap the drive letters, so that the power iso one is the first
Reply 586 of 599, by Sghettikus
power iso was the problem cuz i installed daemon tools lite and mounted it and now it worked
Reply 587 of 599, by Sghettikus
also theres no music
Reply 588 of 599, by BEEN_Nath_58
Sghettikus wrote on 2026-05-09, 15:14:
You converted into an ISO. ISO can't contain music. Consider using bin/cue, mdd/mds, ccd/img, etc
Reply 589 of 599, by Sghettikus
i should have said that the files were bin/cue files, that is my fault i didn't know the terms
Reply 590 of 599, by BEEN_Nath_58
Sghettikus wrote on 2026-05-09, 17:52:
Mech2 has a limitation that it only reads CD audio from the first cd drive only. If you have multiple drives, real or virtual, that could be a problem if you are not on the first drive.
Considering that you correctly converted to bin/cue, and the music is playable in Windows Media Player, the only other choice I see is to rip the music to your local storage, let me know if the previous two ideas don't work
Reply 591 of 599, by Jerad2142
BEEN_Nath_58 wrote on 2024-10-31, 08:58:
You can rip the CD audio in ogg format, in the following names "track02.ogg", "track03.ogg"... "trackmn.ogg", starting with 02, […]
Khoidoan1@hotmail.co wrote on 2024-10-30, 23:30:
I've got the game (MW2 mercenaries Titanium trilogy) running almost perfect thanks to the MW2 installer. The only things that ar […]
I've got the game (MW2 mercenaries Titanium trilogy) running almost perfect thanks to the MW2 installer. The only things that are missing is that the music does not play (even with the CD with audio tracks in the drive) and there appears to be a memory leak.
Basically the game's memory usage will continue to rise until it hits about 1.6 GB if you haven't put in a 4GB patch. Or it hits 3.6 GB if you have put in a 4GB patch. You'll know that the memory leak has completed when the HUD dies and multiple enemies disappear from the map.
You can rip the CD audio in ogg format, in the following names "track02.ogg", "track03.ogg"... "trackmn.ogg", starting with 02, and put the files in a "Music" folder beside the game folder. Subsequently, change the DxWnd configuration for the game in the "Cdaudio" tab from "Play from CD" to "Use audio files".
The memory leak is a real issue, if you are on Windows 10, you can try your luck enabling shim:EmulateHeap in the "Tweaks" tab of DxWnd or alternatively patch:HeapLeak or patch:SafeHeap.
If neither of it works, you can try the "MechVM" installation of the game, that will only use DxWnd to fix the initial mission crash and all other fixes will be from MechVM
Thanks so much for this info, I've always wanted to play through the titanium version of the game but the shortened music kinda ruined it for me, but with this knowledge I was able to take the Dos/WIn95 version of the game's music and swap it into Titanium.
One quick question, is there a fix for when missiles miss their target and slow way down? Its really noticable with the Arrow IV's but I've seen normal missiles doing it as well.
Reply 592 of 599, by Jerad2142
Hate to add to the pile of users having memory issues, I've tired some of the updates suggested here but no luck.
I'm running MechWarrior 2 Mercs Titanium edition on Windows 11.
As a note the memory increase only seems to happen wile having a mech targeted and having it shown on the hud, it stops increasing if no targets are selected or the little window isn't up.
Reply 593 of 599, by myne
eh?
I thought we fixed that?
I played through mercs about a year ago.
Try the installer at my sig link.
I built:
Reply 594 of 599, by Jerad2142
myne wrote on 2026-05-21, 23:44:
eh? I thought we fixed that? I played through mercs about a year ago. Try the installer at my sig link. […]
eh?
Oh yep that fixed the memory leak, sorry I must have overlooked that my bad. How about the missiles slowing down painfully after the first turn, I know on og hardware it wasn't this bad:
https://www.youtube.com/watch?v=PhRrCM4UEgM
I did try lower FPS thinking that could be the issue.
Reply 595 of 599, by myne
On OG hardware, the game was pretty buggy - including missiles pausing
mech2.org might have some pointers
I built:
Reply 596 of 599, by BEEN_Nath_58
DxWnd has had a memory bug fixed in the version released today. Might be worth testing if anyone has issues
Reply 597 of 599, by Jerad2142
myne wrote on Today, 05:49:
Yeah I've seen it on OG hardware as well, I've got an old laptop where to missiles flip around nice and quick and do a good job catching up (not turning into some sort of slow moving shark like the vid above), I've always assumed its an FPS issue but I tried a ton of different FPS setttings in DxWnd and haven't really seen any improvement.
Reply 598 of 599, by myne
Oh you can 1000% get the same result with arrows on real hardware.
Those were always like that. Effective though.
I built:
Reply 599 of 599, by Jerad2142
myne wrote on Today, 16:20:
Yeah I've seen both, they work right on my old 98 laptop, I had them work right on an old windows VM but that had weird latency. but yeah I've seen them do this slow down thing on some other computers I have as well.
