First post, by DragonClaw
I have a trusty WinSetupFromUSB flashdrive with XP, Vista and 7 on it that I've used multiple times to reinstall my retro PC with a 990FX Sabertooth board. However, I recently decided to rebuild my rig with a 990FXA-UD5 board instead and now attempting to boot into either of the 3 OSs results in a
It seems your USB disk was seen as a Floppy/ZIP disk by BIOS[...]
warning. It then tries to launch the PLoP boot manager, which fails. I can boot into PLoP myself after a restart by pressing F2, but that doesn't help either as when it tries to detect the USB drive it either freezes or says no device detected.
On the Gigabyte board, I have legacy USB function enabled, USB storage enabled and it's set to boot from USB-HDD only. The USB drive is plugged into a rear USB 2.0 port, though I tried USB 3.0 for good measure to get the same result. All irrelevant USB devices are disconnected.
After some faffing about with ChatGPT and the grub command line, I figured out that the USB drive was detected as fd0 (that's a zero, the font here makes it look like the letter 'o') when it was supposed to be something like e.g. hd0. ChatGPT recommended I try removing
/shifthd.bat
from the list of boot commands, which failed. I then took it upon myself to try other things like replacing
root (hd%RDSK%,0)
with
root (fd0,0)
and while some of the things I tried allowed the boot sequence to progress further, it still ultimately failed. I don't really know what I'm doing so I might've been doing something silly.
I'm wondering if anyone has any idea as to how to
- either make the flashdrive identify as what WinSetupFromUSB expects
- or tweak the commands in a way that allows it to work regardless
Thanks!
Main PC: B650M PG Riptide | Ryzen 7 7800X3D | 2x16GB DDR5 6000 | RX 7900 XTX
Retro PC (XP&7): 990FX Sabertooth | FX-8320 @ 4.5GHz | 2x4GB DDR3 1600 | HD 7970
HTPC: X99-QD4 | E5 2667 V4 | 4x8GB DDR3 2133 | RX 6700 XT
