Reply 80 of 159, by Jo22
- l33t++
Anyway. It depended a lot on location too
I think same. An possible explanation: Over here in Germany (or western Europe in general), the IBM PC was delayed.
We didn't get it in 1981 like US users did but rather years later in 1983.
And when we got it, CGA was still current, so we bought CGA cards for it (or Hercules cards) or got PC/XT clones with integtrated CGA.
However, just as we did invest in that, EGA came out in 1984 and made us look a little bit stupid.
So we skipped EGA and waited until VGA with simple analogue RGB monitors came along.
That's the simple story, basically. I'm not sure how much true it really is, though. It's just an explanation.
Edit: It also doesn't cover the special case of using existing CGA monitors with EGA clone cards (since productivity software expected 640x350, mode 10h, which needed EGA monitors).
By mid-late 80s there also were complete sets, such as Amstrad/Schneider PC1640 or Schneider Tower AT and Euro AT.
They had gotten EGA support by their time, of course.
By 1988 onwards, VGA also made it into some 80286 motherboards.
Usually those models with a 12 or 16 MHz 286 CPU, I think.
Some disk less PCs meant for Novell NetWare also had Hercules instead (do have one).
Speculation: The older or lower end systems still had EGA (or Super EGA) in mind
but already offered an option for VGA (example: Euro AT has an optional, proprietary 8-Bit VGA card, "Euro VGA", probably due to being derived from Euro XT).
If I had to guess, I would say that the 80286 PC was rather common as a standard PC by 1988-1992.
So in the early days of VGA, basically. At the time, latest software did target both EGA/VGA, I think.
VGA users had access to EGA software, too and probably used it most of time until more VGA software was available.
Text mode on VGA also was better than on EGA. It had combined MDA's fine resolution and EGA's colour fidelity.
