Future Upgrading Suggestions
Reply 40 of 68, by DustyShinigami
So I've been informed that an AMD Athlon XP 3000+ at 2GHz can cause problems and malfunction in 98. Can anyone confirm this? I presume Athlon XP 2000+ and Pentium 4s at 2GHz are fine...? I read in Phil's thread he was using a Pentium 4 at 2GHz.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 41 of 68, by DustyShinigami
I'm a bit unsure if I need to worry about any specific chipset or not? For a Pentium 4 Socket 478?
OS: Windows 98 SE
Reply 42 of 68, by BitWrangler
In the noughts I ran 3 socket A platforms, Via, AMD and SiS with thoroughbreds from 2.1 to 2.6 ghz and didn't have any specfic problems with them. I was running the K6 patch though. This was on 98SE, official updates only.
Reply 43 of 68, by DustyShinigami
BitWrangler wrote on 2026-05-26, 23:44:
Cool. Thanks. Just currently browsing Socket 478 motherboards and wasn't sure if any had advantages/disadvantages over others. The couple I was looking at from Asrock are Intel. There's also quite a lot of choice regarding the Pentium 4s as well. Northwood, Prescott, Willamette, and even Gallatin.
OS: Windows 98 SE
Reply 44 of 68, by Shponglefan
DustyShinigami wrote on 2026-05-26, 23:16:
I did a build with an ASUS P4S533 which uses the SiS 645DX chipset. It was incredibly unstable with Windows 98.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 45 of 68, by DustyShinigami
Shponglefan wrote on 2026-05-27, 12:02:
Thanks for the heads-up. All the more reason why I need some light shed on what works and what I need to stay clear of. And yet looking on The Retro Web, that board has quite a high rating and with no issues reported.
At the moment, I'm looking out for the same board that Phil used as it's supposed to be stable, but there are only so many on eBay, so I definitely want to keep my options open.
OS: Windows 98 SE
Reply 46 of 68, by DustyShinigami
Come across an ASUS P4P8T Rev. 4 for about £30. It got 9.8/10 on Retro Web, though it only supports the Prescott and Northwood Pentium 4s.
OS: Windows 98 SE
Reply 47 of 68, by Shponglefan
For Socket 478, boards supporting Northwood and Prescott processors will be the most common.
I'd recommend sticking a Northwood processor, since they consume less power and therefore run cooler. In most cases, performance differences between Northwood and Prescott processors will be pretty negligible.
Reply 48 of 68, by DustyShinigami
Shponglefan wrote on 2026-05-28, 16:35:
Great. Thank you for the recommendation. 😀 I'll look at getting those parts next month.
I'll likely go for one that supports 533MHz FSB. Possibly a 3.20GHz one. I'm interested in seeing how low I can underclock it as well as seeing how those late 90s/early 00s games run.
OS: Windows 98 SE
Reply 49 of 68, by MagefromAntares
DustyShinigami wrote on 2026-05-28, 16:51:
A 3.2 GHz Northwood is a solid choice, I think every Northwood with that Core frequency had Hyper-Threading support as well, note that AFAIK all 3.2 GHz Northwoods and Prescotts have a 800Mhz FSB.
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 50 of 68, by DustyShinigami
MagefromAntares wrote on 2026-05-28, 16:58:
My only concern is I think I read somewhere that Hyper-Threading is problematic with Windows 98...? Hopefully there's an option in the motherboard's BIOS to disable it.
OS: Windows 98 SE
Reply 51 of 68, by MagefromAntares
DustyShinigami wrote on 2026-05-28, 17:05:
Yes, Hyper-Threading can be problematic with 98 and ME, but luckily most motherboards have the option to disable it.
Reply 52 of 68, by agent_x007
DustyShinigami wrote on 2026-05-27, 12:07:
Are you sure TRW rating is for performance/compatibility, and not completeness of information about it ?
Reply 53 of 68, by Shponglefan
DustyShinigami wrote on 2026-05-28, 01:19:
I looked up this board.
First, the score on Retroweb has nothing to do with quality of the board. It has to do with completeness of information in their database.
Second, that is a non-standard form factor (ASUS TriOptix). It's designed for specific compact ASUS cases, not designed to fit in a standard case. It also only has a single AGP and PCI slot, so it would be very limiting insofar as expansion cards.
Personally I would recommend going with a standard ATX board.
Reply 54 of 68, by DustyShinigami
Shponglefan wrote on 2026-05-28, 18:16:
I looked up this board. […]
Ahhh, I see. My mistake. Still, it would be great if there was a quality rating. But yes, I didn't even realise that about that particular motherboard. I was too busy looking up the model numbers and comparing them on TRW. I didn't even notice or realise that board isn't even a microATX. Very careless of me. >_< But it would ideally need to be a microATX as I have my test build under the desk, which currently has the MSI MS-6156 (BX7) board in it. So it would make sense to put that to use.
OS: Windows 98 SE
Reply 55 of 68, by DustyShinigami
So a few other motherboards I've looked at:
MSI MS-6533E
ASRock P4VM8 (I think the AGP slot on this one is white), but comes with RAM and P4 3.2GHz pre-installed. It's a bit grubby and dusty, but can easily be cleaned up
OS: Windows 98 SE
Reply 56 of 68, by MagefromAntares
DustyShinigami wrote on 2026-05-28, 22:14:
MSI MS-6533E
Hmm, the MSI MS-6533E only supports 400 Mhz and 533 Mhz FSB, while the ASRock P4VM8 also supports 800 Mhz.
However the MSI MS-6533E is a SIS chipset, while the ASRock P4VM8 is VIA, generally I found SIS chipsets to be a bit more reliable and less driver version hunting than the VIA ones.
Personally I would still choose the ASRock one as the 800 Mhz FSB is the official FSB frequency for a P4 3.2 GHz and for P4s FSB frequency really matters because of their relatively low cache sizes compared to general performance, and generally driver version hunting needs to be only done once and after finding the good driver for a VIA board it can be a good performer.
EDIT: Also note that the MSI MS-6533 without any letters at the end only supports 400 Mhz FSB and that will really cripple the performance of faster P4s, so if going that route make sure it is really a MSI MS-6533E.
Reply 57 of 68, by DustyShinigami
MagefromAntares wrote on 2026-05-28, 22:30:
Hmm, the MSI MS-6533E only supports 400 Mhz and 533 Mhz FSB, while the ASRock P4VM8 also supports 800 Mhz. However the MSI MS-65 […]
MSI MS-6533E
Thanks for the info; good to know. I still haven’t really settled on any yet. Just looking up options that will serve my needs, but are also affordable. I would ideally like to get the same as what Phil got in this thread - 10 Reasons for a Pentium 4 Windows 98 DOS Retro Gaming PC :)
Though they’re a bit pricier at £80-100.
OS: Windows 98 SE
Reply 58 of 68, by DustyShinigami
MSI MS-6533E
I reached out to the seller and even the MS-6533E is only 400MHz. So it's looking like ASRock is leading the charge.
OS: Windows 98 SE
Reply 59 of 68, by PC Hoarder Patrol
DustyShinigami wrote on 2026-05-28, 23:17:
MSI MS-6533E
I have one of these ( ASRock P4i65G ) kicking its heels in a cupboard somewhere - yours if you want it...PM me.
