First post, by 385387386
Intall an additional D2583 to C3420, the original one is a C3420.
For M919 v3.2 board.
Thanks all.
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
Now upgraded to Cyrix MII 291.5MHz (maybe PR400)
Thanks all.
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
https://theretroweb.com/motherboards/s/pcchip … ch-m919-ver-3-2 - It's pictured with one and two there, I'd use two from the same batch though, no idea what they do to achieve balance
They do nothing for balancing, the two transistors are simply connected in parallel.
This is bad design when you are using bipolar transistors (you can do it with MOSFETS). In practice one of the transist0rs takes most of the load while the second one idles - unless you carefully select two sampes with identical electrical parameters. Even in this case due to aging sooner or later asymmetries will occur.
Best practice is to use one transistor and when it´s maximum current isn´t enough use a more powerful one with a better heatsink. -> just like every decent mainboard manufacturer did...
majestyk wrote on 2026-05-31, 04:56:They do nothing for balancing, the two transistors are simply connected in parallel.
This explains why the board just stick with only 1 transistor. Thanks for the advice, pairing two of them could cause a nightmare.
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
Matth79 wrote on 2026-05-30, 11:31:https://theretroweb.com/motherboards/s/pcchip … ch-m919-ver-3-2 - It's pictured with one and two there, I'd use two from the same batch though, no idea what they do to achieve balance
Maybe they want to do balance with resistor, but just fake out like L2 cache.
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
