First post, by Rav
Hi.
Yesterday I finally fixed my M919 after all that time I had it!
Well, the Clock don't tick when it's off (it save cmos setting just fine) but it's probably something else
BUT
Of course I did try to OC the hell out of it like any computer I got so I put the FSB to 60Mhz thinking my 32MB stick of FPM 60ns would fail.
But to my surprise, it booted (1 read ws, 0 write ws).
Then I proceeded to do a battery of test (as in the screen shot).
It worked fine without issue (for config 0 and config 1, see screenshot).
Then during the test of config 2, I got a crash in pcpbench and in quake... I was thinking.. Well, the PCI is at 40Mhz, the el cheapo SIS 6326 AGP not AGP don't like it... Let's swap it for my S3 Vision 968...
Other than the fact that the S3 is way more fast, It also crash in the same bench, also doom now....
I ended up switching back to config 0, to redo my initial test. Guess what? I can't finish a pcpbench, nor a doom or quake bench, it crash every single time.
Setting my memory to 3ws/3ws allow me to finish a round of pcpbench or two before a crash but....
Why I worked so well in the first try? I did initially think I degraded my ram or cpu (they where well ventiled...) But I have no issue running the Cyrix at 120 (fsb40) or 100 (fsb50). Even yet, my ram still work fine at fsb50 with 0ws/0ws.
Was I just super lucky that I managed to run thru two battery of bench without any issue for some reason? That's still very... weird...
Now I can't even do a memtest with 60fps/3ws/3ws...
Can someone recommand me something else to test for that board? I don't think swapping bios would change a thing... I do plan to get 50ns EDO but... Why it just worked so fine initially... I did not overvolt anything. The CPU is at 3.5v (board jumpers are set to 3.3v... Voltage is stable even during load.)
