First post, by fsck100
Complete Overhaul - 22 Bugs Fixed - Menu added - Bootdisk img added
This is a real-mode DOS USB driver for 386/486-and-later machines with a UHCI, OHCI, or EHCI controller (USB 1.x/2.0 — no xHCI/USB 3). It handles USB keyboards, mice, and mass storage. The test build runs on FreeDOS 1.4 under an HDPMI DPMI host and logs to COM1 at 9600 8-N-1.
What's new in this major version:
  • 22 bugs fixed (19 from the audit list, 3 found along the way) — including an OHCI register-read fix that revives every non-Intel/VIA controller (SiS, ALi, NEC, OPTi, Compaq), and two fixes that stop the driver hanging on a USB mouse.
  • A boot-time menu tester: pick keyboard+mouse, mass storage, or both; switch builds; set baud.
  • A ready-to-write 1.44 MB bootable FreeDOS floppy image — boot straight into the tester with memory management already set up.
Licensing, up front: everything in the package is open-source or freeware with explicit redistribution rights — no abandonware, no grayware. The driver is GPL-2.0 (fork of crazii/USBDDOS); the FreeDOS pieces are GPL/open-source; HDPMI is Japheth's freely-distributable HX runtime; MODE is FreeDOS GPL-2.0. Per-file detail is in LICENSE.TXT.
Testers wanted: enumeration, hubs, and no-hang behaviour all check out in emulation (QEMU + Bochs), but the one thing emulators can't exercise is real USB-to-PS/2 mouse motion and buttons reaching a DOS mouse driver on actual hardware — that, plus how it behaves on your chipset, is what this round is for. Boot it on a 386/486+ box, capture the COM1 log while you exercise a device, and file a bug. A hang or crash (rather than an unsupported device being safely ignored) is the most useful thing to flag; REPORT.TXT lists what to note.
Please file bugs as GitHub issues — I can't monitor forum replies frequently, so a reply in this thread is not a reliable way to reach me:
https://github.com/netrunner01/USBDDOS/issues
Download — files-only, or files plus the bootdisk image:
https://github.com/netrunner01/USBDDOS/releas … /v2.0.0-alpha.1
THANK YOU!
Reply 3 of 13, by fsck100
vetz wrote on 2026-05-31, 15:22:
If this is developed with AI tools/assistance (which it very much seems like) you have to disclose that according to forum rules, or thread will be deleted.
Ok, thanks. I'm a developer and analyst. And yes, I use AI daily in my job. Didn't even occur to me. The bugs and patches are handled using AI assistance and automation.
Reply 4 of 13, by vetz
fsck100 wrote on 2026-05-31, 15:33:
Thanks!
Else good initiative/project, DOS USB support needs some love:)
Reply 5 of 13, by wierd_w
my asus anachronist laptop (AMD E1 cpu) has an AMD EHCI / OHCI with VEN number 14B7.
Previously it was hanging when trying to emumerate devices. Most recent test has it loading with /HID and /DISK
Is there any plans to extend /HID to support USB joystick emulation?
Reply 6 of 13, by fsck100
vetz wrote on 2026-05-31, 15:45:
Thanks!
Thanks. I got sick of patching one bug here and there. So I pulled down every USB 1.1 and 2.0/UHCI/OHCI/EHCI specifications and implementation doc I could find. That lead to even more relevant document sets being found. The doc stack I finally ended up using to audit against is huge. It's nice to see large numbers of bugs patched and (emulation) tested, but it has been extremely painful. The last three bugs were the worst. They came after all the audit bugs were fixed, showed up only in a "final" round of controller/hid/msc combinations testing. Three more rounds of patch, smoke test, regression test, full test matrix, commit, refresh baseline, start again.
Reply 7 of 13, by fsck100
wierd_w wrote on 2026-05-31, 16:40:
Sorry, no. Keyboard, mouse and mass storage only. What you want would be a feature request to the upstream project. Please include "[Feature Request]" in the title so he knows it's not a bug report. Here is the link: https://github.com/crazii/USBDDOS/issues .
PLEASE let me know what version of the driver you are testing with. Thanks.
Reply 8 of 13, by wierd_w
My most recent test was with your current released alpha. (version 2.00 alpha 1.1)
(as for the feature request, it would actually be THIS project that does USB Joystick emulation on UHCI controllers. But since my box does not have a UHCI controller, I cant use it.)
Reply 9 of 13, by crazii
fsck100 wrote on 2026-05-31, 16:43:
Thanks!
Thanks for your effort!
Is there any change to merge into upstream? Right now I don't have time to work on it or check your new coming bugfix, sorry. But I would do it when I have more time.
Thank you again 😊
Toshiba Satellite Pro 4300 - YMF744, Savage IX
Toshiba Satellite 2805-S501 - YMF754, GeForce 2Go
IBM Thinkpad A21p - CS4624, Mobility Radeon 128
main: Intel NUC11PHKi7C Phantom Canyon: i7-1165G7 RTX2060 64G 2T760PSDD
Reply 10 of 13, by crazii
Just checked github and there are several PRs you created. sorry that I didn't receive any notifications here.
Thank you.
Reply 11 of 13, by crazii
Thanks for your new PRs!
BTW I found the GitHub notifications are sorted from oldest to newest. 🤣
Now it's OK.
Reply 12 of 13, by myne
This sounds pretty cool.
Nice work.
Might be worth talking with https://github.com/lordofmice/hidusbf
I built:
Reply 13 of 13, by RayeR
I just tested new beta on my PC (sign.) and it's on a good way - now it doesn't hang and even successfully detected the mass storage device (USB flash disk) and assigned a drive letter for it. Problem is, that I can see only the first directory entry on that disk (tried both FAT16 under MSDOS 6.22 and FAT32 under MSDOS7). Volume label is readed correctly. Both WC and DJ versions behave the same. So it seems to be closer to the success.
Here are some logs from serial terminal:
