Reply 420 of 479, by Chkcpu
sizzlinbeef wrote on 2026-05-31, 17:17:
Yes, jumpering JV6 gets the correct 2.5v. […]
Chkcpu wrote on 2026-05-30, 19:51:
First close only JV6 and check if you indeed get 2.5V Vcore. Then also close JV7 and check the voltage. Depending on how the JV6 […]
Then also close JV7 and check the voltage. Depending on how the JV6/JV7/JV8 resistor network is connected, you will see the Vcore either go down or go up.
Repeat the experiment with all other JV6/JV7/JV8 combinations.
If the voltage goes up with more than one JV6/7/8 jumper closed, a final test with all three JV6/7/8 jumpers open may reveal the lower Vcore you want to find.
I hope this procedure is clear and I’m curious what you will find.
Happy testing,
Jan
6-7 closed 1.93v
6-7-8 closed 1.73v
7-8 closed 2.04v
6-8 closed 1.95v
Unfortunately I can't confirm any of these result in a working system. I tried booting this board before testing. Using default settings for a pentium MMX (I tried a 166, 200, 233), can't get the thing to post. No video output. Tried different VGA, RAM, deoxit on all slots, alcohol clean, etc. I think time has taken it's toll on something on the board. It may be related to getting 3.6v on the VIO transistor when it should be 3.3v with JV1 and 2 open and JV3 set to 2-3. It has been probably a decade since I last tried booting it, so not surprising.
Thanks for reporting your test values.
So a 2.2V setting was not among them, but you found a nice 2.04V setting for a K6-2+! 😀
I’m sorry to hear the board won’t boot. The CMOS backup battery inside the DALLAS or BENCHMARQ RTC chip is probably dead. This sometimes causes a board to stall early during the Power-On-Self-Test.
Do you have a POST analyzer card to see where the boot process hangs?
Cheers, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 421 of 479, by PC@LIVE
Ciao Jan,
I wanted to let you know that I downloaded the BIOS version 2.0 that you provided me, but currently I can't try it, because I'm away for work, but I have the ZIDA 5SVA-E motherboard on the bench, so as soon as I have the opportunity to dedicate a few minutes to it, I'll upgrade the BIOS, then I could try other CPUs, currently there is a Cyrix MII 300 (233 MHz), but if I remember correctly, it is possible to select lower voltages, for AMD K6 CPUs from 2.2V for example, maybe it could be possible to get up to 2.0V, but I don't think you can select lower voltages, this I think is possible only after modifying the motherboard, which I wouldn't do anyway, not having this need.
Greetings 🖖
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 422 of 479, by Chkcpu
PC@LIVE wrote on 2026-06-01, 09:08:
Ciao Jan,
Greetings 🖖
Ciao Elio,
Thank you for going to test the patched Zida 5SVA(-E) BIOS.
If you can test it with a K6-2+ or K6-III+ that would be great.
But there is no hurry, so take your time.
Earlier you found that this board uses a HIP6008CB controller, so by using the four JP9 jumpers, the Vcore can be set from 2.0V to 3.5V in 0.1V increments.
Pulling all JP9 jumpers OFF will generate 2.0V.
Placing jumper JP9/1-2 will add 0.1V
Placing jumper JP9/3-4 will add 0.2V
Placing jumper JP9/5-6 will add 0.4V
Placing jumper JP9/7-8 will add 0.8V
Using any combination of these 4 jumpers, all 16 Vcore settings from 2.0V to 3.5V can be made.
And of course the JP8 jumpers block must be at position 1-2 for dual-voltage CPUs.
Greetings, Jan
Reply 423 of 479, by sizzlinbeef
Chkcpu wrote on 2026-05-31, 19:47:
Cheers, Jan
Interesting. I've had many dead Dallas rtcs, this particular one is an ODIN clone, but haven't heard of a dead one preventing a computer from posting. They've always just annoyingly lost the BIOS settings on reboot. I'll battery mod this one and see if that changes anything. I do not have a post analyzer board.
Reply 424 of 479, by Mike_
Mike_ wrote on 2026-05-31, 07:18:
Actually I also noticed that hidden setting after I had posted the ROM files, but unfortunately it didn't help. […]
But I got an idea what might be causing this on hardware side. Near south bridge there are two IC footprints, but there are only two resistor nets there instead.
The attachment south_bridge.jpg is no longer available
Those resistor nets are between ISA slot and south bridge on address lines 0-15, but 470Ω is awfully lot of series resistance even for a slow bus like ISA. On 686B south bridge those lines are multiplexed with secondary IDE's data lines, so maybe the point is to prevent ISA bus messing with whatever is happening on secondary IDE. Looking at pictures of GA-7ZX, which has ISA slot as an option, there are two TI's "F245" chips.
The attachment ga-7zx.jpg is no longer available
https://theretroweb.com/motherboards/s/gigabyte-ga-7zx-1.x
I suppose it could be this? Locations of GND and Vcc pins match, and OE on both sockets is low when board is running, ie. it's enabled. I guess Gigabyte figured out that a cheap resistor net would suffice for reading from a slow BIOS chip during startup, and there's no need to have an actual IC there. 😁
https://www.ti.com/lit/ds/symlink/sn54f245.pdf
Unfortunately soldering in these chips didn't help, either. 🙁 So there must be something else going on. Is there some DOS utility that could be used to dump PCI configuration space? It could be that some PCI-ISA bridge settings are out of whack... for example, I wonder if this part from datasheet means that by default 16bit ISA bus is turned off or something?
The attachment isa_control.png is no longer available
POST diagnostics card also arrived, and it seems to work correctly on the ISA slot. I also tried Tie Fighter a bit more, and it appears that some sounds in the intro, such as the spacecraft flying around, sound OK but speech is garbled. It's as if speech would be way slower than it should be.
Reply 425 of 479, by Chkcpu
Mike_ wrote on 2026-06-04, 15:32:
Hi Mike_,
Yes there is a DOS tool to dump the configuration space of all PCI devices.
It’s called PCISNIF and the program creates a detailed log-file when hitting the F2-key.
You can download this PCI Bus sniffer DOS tool from an earlier reply in this thread:
Re: DIY Bios Modding guide Jan Steunebrink k6-2+/3+ 128gb
Cheers, Jan
Reply 426 of 479, by Mike_
Chkcpu wrote on 2026-06-04, 19:03:
Hi Mike_, […]
Hi Mike_,
Cheers, Jan
Hello, Jan. I just tried another tool called TweakPCI and I read registers 0x40 and 0x42. It appears that "Extended ISA bus ready" and "MCS16# Output" are disabled... I wonder if this could cause problems with 16bit ISA cards?
I'll try that PCI bus sniffer tomorrow.
The attachment isa_clock.png is no longer available
C:\TEMP>tweakpci -b 0686 1106 b40
TweakPCI - PCI configuration tool v1.0 by TimmermanV
Tweaking device: DeviceId 0x0686, VendorId 0x1106, DeviceIdx 0x0
Device found: BusNr 0x00, DeviceNr 0x07, FunctionNr 0x0
Register 0x40 (8-bit)
Cur value: 0000_1000
C:\TEMP>tweakpci -b 0686 1106 b42
Register 0x42 (8-bit)
Cur value: 0000_0000
Reply 427 of 479, by myne
Use wpcredit from 9x.
It should have an appropriate pcr file.
I built:
Reply 428 of 479, by myne
Here. This might help.
It's an automatically converted K7m pcb and rudimentary schematic.
Looks like Asus didn't make a 686b board with isa so 686a will have to do.
I built:
Reply 429 of 479, by myne
I assume you populated the unpopulated resistors here, right...?
In particular DRQ/DACK5 stand out to me.
I built:
Reply 430 of 479, by Mike_
myne wrote on 2026-06-05, 06:05:
Here's a picture before I installed the ISA slot. Most of the passive components are already populated, the empty resistor net was for address lines 20-23 but AWE64 doesn't use those anyways. The resistor for DACK5 is missing here as well (I noticed that it was missing and I populated it).
Quickly looking at it, it appears that at least most of the components in your picture are already populated, but I'll check it out later today.
The attachment isa16bit_area.jpg is no longer available
Reply 431 of 479, by myne
Drq/dack5 was what stood out to me.
Everyone a hundred years old memorised irq 5 dma 5,7 220 330
I built:
Reply 432 of 479, by Mike_
myne wrote on 2026-06-05, 06:20:
Everyone a hundred years old memorised irq 5 dma 5/7 220 330
Yes, I noticed that earlier and added a resistor there.
Reply 433 of 479, by myne
What's the 4th from the right missing resistor go to once it goes through at "D1" ?
I built:
Reply 434 of 479, by Mike_
myne wrote on 2026-06-05, 06:25:
That missing resistor is shorted out by the trace. I don't understand why there are pads to begin with. But it goes to S_IRQ connector near BIOS chip and also some test point near south bridge IIRC. But Creative's diagnose.exe says DMA5 is working after I installed the resistor, so I think that's probably fine now.
https://theretroweb.com/motherboard/image/7zx … d2076084371.jpg
Reply 435 of 479, by myne
It would seem that something somewhere isn't going where it should.
The good news is you can reasonably make some assumptions and cut down your test/search "area"
https://dosdays.co.uk/topics/images/sb_ct3600.jpg
https://dosdays.co.uk/topics/images/ct3600_6.jpg
It's not unreasonable to assume that the missing pins on this random card are not relevant to yours.
Test/trace the remainders - including the 8 bit part.
I built:
Reply 436 of 479, by Mike_
myne wrote on 2026-06-05, 08:40:
It would seem that something somewhere isn't going where it should. The good news is you can reasonably make some assumptions a […]
POST diagnostics card seems to work fine, so probably at least pins needed for 8bit writes work. This should narrow it down further.
Reply 437 of 479, by Mike_
Looks like there's no 14MHz clock on OSC pin, and AWE64 does seem to have contact on that pin, unlike AWE32... and unlike AWE32, it doesn't seem to have any crystals on board either. Maybe this could be an issue?
EDIT: And yes, there seems to be another missing resistor...
The attachment osc_trace.jpg is no longer available
EDIT2: And I got it working finally. 😁
Reply 438 of 479, by myne
yay
So... I was accidentally on the right track when I asked about the xtal 🤣
I built:
Reply 439 of 479, by myne
Now you have to write a how to guide for the next guy in 6 years who googles "how do I...?"
I built:
