First post, by tsalat
Hi everyone,
I hope all of you are doing great!
I got this board a time ago (https://theretroweb.com/motherboards/s/unknown-386sx-ht18) - I am sorry I thought I have a photo on my phone of the board but unfortunately not, the board looks, however, the same as on the link.
Anyway, the board does not show any sign of life from the beginning and therefore I have decided to look around the KB Bios, RTC, and BIOS and de-soldered everything to see if there is any damage caused by the battery - to my surprise there wasn’t any damage or damaged traces. After soldering everything back in sockets the board is behaving the same - just a note, I didn't have the scope at that time so I was not able to look on the signals at that time.
After I got the scope I have checked all the OSC on the board, all good.
The KB Bios and the RTC is outputting on the Crystal I/O, however, no life on the BIOS at all.
I have checked the signal to the CPU on CLK2 and the CPU gets only 16MHz but according to the documentation it should have 2x the CPU frequency and thus 50MHz.
I have found the documentation for the HT18/C (https://theretroweb.com/chip/documentation/ht … 98435658181.pdf) and the input clocks are fine, PROCLOCK output as measured on the CPU only 16MHz. According to the documentation the 16MHz is if the HISPEED pin on HT18/C is low, and it is low indeed.
The CPU is not getting any hot from what I have tried, and now I am not sure about how this should actually work, hence decided to ask 😀.
- Does the CPU should be at the beginning at low SPEED triggering the HT18 to get HISPEED?
- The HISPEED pin seems to be running to the KB Bios - does that make sense?
- Any idea what to try next?
thank you and best regards, Tomas
Reply 1 of 2, by tsalat
tsalat wrote on 2025-02-03, 15:25:
Hi everyone, […]
Hi everyone,
Ok, so my bad about the HISPEED low/high - found out that it was caused by the jumper within the TURBO switch - silly me.
Which means that this is working although the frequency to the CPU is 16MHz instead of 50MHz no matter the HISPEED is low or high.
not sure what to try next but considering no signal on the ISA port it looks to me that the CPU is simply not executing anything. I will try to measure more while I will have time but if anyone would have any suggestion, it would be appreciated.
thank you, Tomas
Reply 2 of 2, by Toportyán
Hi there,
It is absolutely normal that the CPU is not running at full speed initially.
The HT18 uses CLKASN (32 MHz on your board) divided by two, so the PROCCLK is 16 MHz. As a result, the CPU will run at 8 MHz, just like in Turbo Off mode.
The Turbo High-Speed setting and the corresponding BIOS setting may be ignored by the chipset. I do not know the exact point at which the chipset enables Turbo mode.
I hope it is not too late.
