First post, by ludicrous_peridot
Since the original question in general banter did not get any suggestions, I ended up forking JojoDiff, which I would probably have had hard time even finding in the first place - but an LLM brought it to my attention. It builds and operates in DOS now, and I am adding a human (as in edit.com/notepad wielder type of human) readable and editable format (and also for multifile patching) for the original author's algorithm.
Here it is work in progress.
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - CMI-8738 - CM-300 - Saitek ST-30
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 - X3MB
https://archive.org/details/peridot-26
Reply 1 of 3, by twiz11
ludicrous_peridot wrote on Yesterday, 21:47:
i wish we werent reliant on DOS4GW.EXE. Can I replace it with DOS/32A or GCC with DJGPP? I dont like that Open Watcom license
Reply 2 of 3, by ludicrous_peridot
Thas sounds like a reasonable thing... However having read a bit, I get an impression nobody seems to like that Open Watcom license. I am actually perplexed and not sure that stubbing with another extender will fix the licensing issues in this case, because:
- it's unlikely they are GPL3
- Watcom standard library remains (and also for the real mode binary)
So, since I find it quite confusing, any advice on the path forward? Seeing a DOS hobbyist project that includes GPL3-licensed code or dependencies and ships binaries would be a good start.
Reply 3 of 3, by LSS10999
twiz11 wrote on Yesterday, 22:49:
I think if the binary is compiled with OpenWatcom you can just use DOS32A to launch it. Everything should work unless it's something specific to DOS4GW that DOS32A might behave differently.
As for GCC/DJGPP, you'll be using CWSDPMI or HDPMI32 (from HX DOS Extender).
