Yamaha XG emulation at last
Reply 140 of 149, by hockinsk
AI is nowhere near able to take a hardware ROM and convert to software emulation or even create valid blueprint of it. Just like anything that came before it, it's a tool and good at some things, n0t at others. Even with AI, all of the bugs, misunderstood bytes and broken dsp in mame are still there. The only thing I've used AI for was to document mame's code to understand what needs to be coded in dsp and the parameters for some of the midi dispatcher and build the plugineditor UI because I hate coding UI. I also used it to write a quick script to brute force me about 1000 dpcm decoder variations to finally work out what mame doesn't emulate correctly and has DC offset issues too.
As for XG being dead, the main issue is now even midi drivers for say my MU2000 no longer work on Windows and yamaha removed them, so even hardware is becoming less desirable to use if you want specific XG sounds. That's what most people love about XG, is that many sounds are so familiar they want something convenient. So far no rompler of samples really sounds correct or better than an MU2000.
Reply 141 of 149, by tcaud
Well then there's your route: update the MIDI drivers for modern Windows, even Linux. Don't need to understand Yamaha's methods to do that, just a decompiler.
What happens with AI is people contribute complete projects to it with notes. The AI alone does not do the job... there is a filter which identifies high value code and recommends it to the analysis teams for inspection and curation. In the case of the MAME project the filter would flag the code by noticing the name "Yamaha" and the team would extract the DSP bits and specially train the AI on it make it more competitive with real engineers. Because it's incomplete they might not prioritize the project immediately, but if someone did a decompilation and put it on Github somewhere then they'd use it to fill in the gaps in the MAME driver...
Reply 142 of 149, by hockinsk
As I said in the beginning. Th MU Hardware has many limitations and SYXG50 is cracked and decrypted with many restrictions because it was never designed for 3rd party hosts and most hosts don't' support sysex anymore to the VST layer and XG was obviously extended beyond GM. Software opens up to improve not only sonic quality but many other things. MPE, oversampling, advanced filters, improved imaging, more advanced interaction with host modulation, audiorate modulation etc.
As for AI, it already knows everything about a Yamaha swp30, there's nothing to teach it with. It wrote a script to geneerate 1000s of decoded dpcm, I worked out what mame missed, AI learned nothing new, not even what dpcm mode mame missed.
Reply 143 of 149, by zaphod77
i have had little issues using vst midi synth as system driver and getting the sysex through, which is needed to playback GS and some XG stuff.
and mame is still quite off.
s-yxg50 was designed to be loaded into SOL2.
Also since your mu2000 can't be used in windows anymore, do you have a solution for that for playing back all ye olde XG midi files?
Reply 144 of 149, by RetroGamer4Ever
AFAIK, the MU2000 drivers for XP were removed, but the subsequent Windows OS are still supported, though someone probably has the XP drivers somewhere.
Reply 145 of 149, by tcaud
The sitch has been developing rapidly of late.
see
https://www.facebook.com/groups/xgcentral/pos … 92757837467575/
Microsoft is tightening security around Windows in advance of serious cyberattacks probably coming America's way. It's becoming a problem for a lot of people, not just Yamaha users.
Wait... are you Sam Hocking? Guess you're already aware then.
Reply 146 of 149, by zaphod77
here's the driver.
https://usa.yamaha.com/support/updates/usb-mi … driver-win.html
released 2026-05-22, but it no longer claims compatibility with windows 11. it just says windows 10 64 bit driver.
3.1.4 did work on 11 before MS change, but now you can no longer download it, because it no longer works.
So yes, the problem is real, which mean we actually DO need an E.S.P. for XG Level 3.
The only way to fix it is to buy an additional windows 11 supported usb midi interface, and hook that to the normal midi ports.
Ironically, Roland makes the working USB to normal midi interface. 😀
Reply 147 of 149, by tcaud
I followed the link and looked for it in the Wayback Machine but it wasn't there, so I saved it to there.
If someone had bothered to save the page when it had the Win 11 driver then perhaps it would still be accessible... sad 🙁
Oh well, I'm sure Yamaha won't let the sitch linger.
Reply 148 of 149, by silvally03@
hey, does the muxg2k have peg and aeg?
Reply 149 of 149, by hockinsk
Yes, it has a more advanced AEG, PEG too I've also added FEG per Element, which is part of the voices but Yamaha never exposed it.
Yamaha, released a new midi driver for win 11 a few days ago. It probably just needed signing and updating so the removed the previous version.
