Reply 40 of 58, by BEEN_Nath_58
I installed a VM and it seems like some of the issues were coming from the GOG installation, to both the GOG game and the DVD game. First the SW mode scaling issue was gone so I could handle it correctly with DxWnd. Next the GOG game stopped crashing.
The first red flag was seeing the GOG executable setting the classic window style. They were compatibility setting and then deleting them with DxWnd's setting, both games were consistently starting up. GOG has an advantage here: its newer executable (does anybody know about Gulfino's patch?) is better compatible with DxWnd's blitting techniques, so I could fullscreen it directly. The videos scale correctly and the Captions are visible.
The DVD version has a lot more problems. Although both games are running on ffdshow, maybe ffdshow installation uses a different renderer than what the newer GOG executable mentions (probably something like VMR9?). I can force it to use Overlay which works better. Then it also doesn't show the captions unless a video stops and trying to fix it again degrades video rendering.
MIDI is another issue: Coolsoft MIDI Mapper should do it
Also certain graphical issues on my Nvidia, and DDrawCompat is more tolerable of the video than dgVoodoo2
Reply 41 of 58, by DustyShinigami
Talk about 'good timing' or when something is 'meant to be'... Paid off my credit card and have a fresh new statement for the month and boom - a vintage 12x DVD drive pops up on eBay from 2000 for as little as £13. It is made by a brand called Delta, which I can't say I've heard of though.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 42 of 58, by DustyShinigami
...Or not. As usual, nothing is ever straight forward for me. To begin with, the drive keeps getting stuck when pressing the eject button and secondly, it's not recognising any discs at all. A game disc, a CD-R, and a DVD-R. 🙁
OS: Windows 98 SE
Reply 43 of 58, by MagefromAntares
DustyShinigami wrote on 2026-06-06, 18:54:
The getting stuck part of the problem is most likely easily solvable, most likely something needs some lubrication or a simple mechanical misalignment. The not recognising any discs is a lot more troubling, if the drive is easy to disassemble then the lens might be cleaned, use a mild cleaning agent to clean it. Remember don't operate a DVD drive with the case open, so if you are doing interior repairs always put it together before trying to use. Damaged DVD drives can be replaced, vision loss most of the time is permanent! (Also note that while most of the time DVDs use red lasers there are a few which uses lasers like CD-ROM drives in the infrared range, in that case you cannot see it, but it can still damage vision)
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 44 of 58, by DustyShinigami
MagefromAntares wrote on 2026-06-06, 19:10:
Hmm. Taking apart a DVD drive isn't something I've done before, and knowing me, I'd probably make it worse. ^^; At this point, I honestly can't be bothered. I've messaged the seller to let them know, so I'm hoping I can get a refund. And then just buy a different one. Preferably from a brand I know this time.
OS: Windows 98 SE
Reply 45 of 58, by DustyShinigami
I understand Pioneer are meant to be a good brand...? Because I've seen a few of those listed. Both a DVD and CD-RW combo.
OS: Windows 98 SE
Reply 46 of 58, by AppleSauce
DustyShinigami wrote on 2026-06-06, 19:15:
If its any help the DVD drive i used to get tex murphy overseers dvd edition working was a Pioneer DVR 106 or a DVR107
Reply 47 of 58, by DustyShinigami
AppleSauce wrote on 2026-06-06, 19:44:
Okay, interesting. Thanks. However…
And I suspected this was going to happen… I decided to use a spare SATA DVD drive I had lying around and hooked it up to the 98 PC using my IDE to SATA adapter. Just like me not to think of doing that sooner. 🙄😅
Anyway, I installed the game using the drive, and despite the INI file having all 5 drives assigned to H, which is what it is, the game STILL asks for the disc in drive H. 😂
OS: Windows 98 SE
Reply 48 of 58, by DustyShinigami
Okay, I'm starting to think it isn't my DVD drives that are the problem, whether internal or external, but rather, how the DVD has been set up. I can't quite remember what I did, but I think I followed this guide...? https://www.unofficialtexmurphy.com/viewtopic.php?t=1576
...or parts of it anyway. So I'm not quite sure now which steps are correct and which aren't. I mean, I presume all the files are present and accounted for. I have a folder I used to add to a DVD-R, which is over 4GB. And I believe the 1.04 patch has been added, too. So unless anyone knows of another guide for creating a DVD version...? Different from the one I've linked...?
OS: Windows 98 SE
Reply 49 of 58, by AppleSauce
DustyShinigami wrote on 2026-06-06, 23:48:
You should just stick to using the actual dvd version and not the cd version to dvd conversion which just adds more complications,
the games already a pain in the ass to get working and you'll end up with even more headaches.
Reply 50 of 58, by xcomcmdr
Yes, just use the DVD version from the start. The other way around is why you have problems.
Reply 51 of 58, by DustyShinigami
AppleSauce wrote on 2026-06-07, 04:26:
You’re probably right to be honest. Trouble is, nothing comes up on eBay for me. There’s only one I can see but it includes everything else - box, CDs etc., which I already have. 😕
EDIT: Never mind - forgot to set it to Worldwide/Europe 😅
OS: Windows 98 SE
Reply 52 of 58, by DustyShinigami
Okay, I don’t honestly know what I was thinking or trying at the time (I find it’s best not to ask), but I was clearly trying to put my own DVD version together when instead I should have just taken the DVD image I had and burnt it to a DVD-R. Then after installing the game, I added the 1.04 patch. No more asking for the disc!
I did have to switch back to my P3 and overclock it for the videos to run smoothly, but yeah - problem solved. 😄
EDIT: Okay, there is a bit of a pause between videos for some reason.
OS: Windows 98 SE
Reply 53 of 58, by DustyShinigami
I’m guessing others have had a similar issue with the DVD version using a Pentium 3 and 256Mb RAM…? I did notice the recommended spec lists 1-1.4GHz and 512Mb RAM. As well as Windows XP. I may have to save the DVD version for the other build and just stick to the CD version on my main one.
OS: Windows 98 SE
Reply 54 of 58, by xcomcmdr
Do you have DMA enabled on the drive ?
I played it on a P3 with 512 MB of RAM just fine.
The game doesn't like Windows XP.
Reply 55 of 58, by DustyShinigami
xcomcmdr wrote on 2026-06-11, 19:54:
Oh right. The info I saw on pcgamingwiki must be wrong then. But yeah, I'm sure I enabled DMA on each of the HDDs. Though I don't think a couple I have as they're hooked to two separate controllers and don't give me the option. I will have to check though.
OS: Windows 98 SE
Reply 56 of 58, by DustyShinigami
Yep, DMA is enabled only on drive C and D. D being the drive the game is installed to.
OS: Windows 98 SE
Reply 57 of 58, by DustyShinigami
Yeah, something is definitely amiss with the image of the DVD I've converted to a DVD disc. For one, the opening credits intro is really quiet compared to the other videos. I've also tried having 512Mb of RAM, using my Riva TNT and my Geforce 4 Ti, but there's still always an unnaturally long pause between videos.
OS: Windows 98 SE
Reply 58 of 58, by DustyShinigami
I'm totally stumped with this one. Trying another image and burning that to a DVD gives the same results. A long pause between video sequences. Also, are the videos supposed to be this squashed...? Because if so, that and combined with the pause issue, I think I'd prefer the CD version.
The attachment IMG_5568[1].JPG is no longer available
And I'm equally annoyed that the credits sequence is so damn quiet. Again - not an issue with the CD version.
OS: Windows 98 SE
