First post, by Retronerd878
Got this HD3850 that doesn't want to post at all. Even with a secondary PCI card, no image on the working VGA adapter.
I found some missing components. If someone knows the values that would be great:
C580 = 10 nF
C519 = 1.2 uF
C471 = 1.2 uF
C117 = 10 uF
C63 = 1.2 uF
C614 = 100 nF
U7
U7 was knocked off and holding on just by one pin. I managed to straighten it and solder it back. However, I think that made it worse. When U7 was not connected, the PCI post analyzer card went further to code 2A 20. But now, after soldering it back in place, the post code cycles through just one code and settles at D1 D4. Maybe U7 is bad from the hit and needs replacing. The marking on U7 is Z08L
