Reply 59180 of 59204, by MattRocks
- Oldbie
I'm sorry, I have more important things to do on a Sunday so just a quick fire response..
The extra cache on K6-2+ means it can setup triangles multiple times faster than the K6-2. It also means it can spin through the orchestrating software layers (e.g. Direct3D) faster. That brute force is going to boost FPS on the K6-2+ regardless of PCI/AGP bus.
I had a 3Dfx Banshee SGRAM, so 3Dfx definitely put SGRAM on AGP cards too. It's not a PCI/AGP differentiator, but it shows that test cards need to be carefully hand picked before running PCI/AGP comparisons.
In the later PCI-via-southbridge vs 8xAGP-3.0 comparison, not only is the PCI slot severely handicapped by being architecturally demoted to the chipset periphery, but the actual cards compared a 64-bit VRAM PCI card vs 128-bit VRAM AGP card. As a PCI/AGP comparison it's totally ludicrous!
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i5) → x86-64(i7) ] * lost
