What modern activity did you get up to today?
Reply 1640 of 1649, by BitWrangler
Getting a high fibre diet in the SW Ontario regions now, might encourage me to move further into the sticks.
https://swiftruralbroadband.ca/
Reply 1641 of 1649, by Repo Man11
So I finally got around to testing out the hardware I'm accumulating to upgrade a cousin's computer to Win11. I scored an Asus B550M-A motherboard for free a few months back, the Ryzen 5 3500X was a reasonable deal at $75.00, I picked up 16 gigs of used DDR4 for $30.00 just before the prices went nuts, and I tested everything today and it all works fine. I'll have her buy an M.2 drive (I tested it with an old SSD) and she'll be all set.
Reply 1642 of 1649, by gerry
Repo Man11 wrote on 2026-06-01, 03:45:
that sounds good, slowly building up as and when rather than getting all at once, being patient for prices and finds
Reply 1643 of 1649, by Repo Man11
BitWrangler wrote on 2026-06-01, 02:39:
I loved living miles out of town, surrounded by almond orchards, but man the internet access was grim. Dial up only, over very old phone lines to the max speed was only 26.4 k - there was never any need for a dial up modem faster than a 28.8 as that was faster than the best possible connection. I lived with that for years, then finally spent the money for satellite internet. That was expensive while still being slow, but it was better than dial up. Then came a wireless internet service that was initially very good, but then they oversold it (ugh, Netflix) and trees grew up and choked off the line of sight signal.
My mother didn't know how good she had it. She also lived in the countryside, but she was near where the phone service hub was located, and as a result she had the fastest dial up speeds I've ever seen. It would consistently connect at 48 k, and seemed more like DSL than dial up compared to what I was used to.
Reply 1644 of 1649, by Ozzuneoj
Repo Man11 wrote on 2026-06-01, 17:24:
This is how things were for me growing up as well. We lived in the woods outside of a small town ~100-150 miles from any decently sized city that anyone has ever heard of.
We had dial-up that would connect at 24.6k usually... but sometimes, on a good day, it would connect at 26.4k. I remember downloading most files at around 1KB-2KB per second, with the rare "fast" connections getting up to 3KB\sec. So, a 1MB download usually took anywhere from 5 to 15 minutes. Getright download manager and other things like it were absolutely required for anything that was more than a few MB in size because it was likely that the download would need to be paused and resumed later due to getting disconnected or having to disconnect the line to use the phone (we had two lines but one was being used frequently by another family member who needed it, so I had to steal the main telephone line to connect my PC to the internet in the evenings).
We dealt with this until ~2001-2002(?) when the local cable company finally provided broadband. The first cable internet package we had was, I believe, 768k down and 128k up. It was like traveling to another planet it felt so fast. Nothing was ever the same after that.
Still... having dial-up in our house was better than having to drive to a relative's house with a pile of floppy disks so we could download things, save them to disks and then bring them back home to find out if they worked or not.
Reply 1645 of 1649, by Repo Man11
gerry wrote on 2026-06-01, 16:51:
She was in a bit of a panic a few months ago until I showed her that she could sign in to her Microsoft account and continue to get updates. But October will be here before you know it, so I have to get this done.
Reply 1646 of 1649, by lti
Ozzuneoj wrote on 2026-06-01, 18:39:
At the end of the COVID lockdowns, I did that to download a 75GB software installer for work. The I learned that downloading add-ons from within the program would fail because there was a fixed internal timer that would abort the download if it took too long.
On that note, my Internet is extra-shitty today. I'm getting 3Mbps.
Reply 1647 of 1649, by lti
I switched back to my older computer, and the WiFi problems I thought I fixed are back. I'll keep running it and see how much it affects room temperature. Last night, this room was hotter than the non-climate-controlled garage. Also, I see that the chipset is getting hotter (and the heatsink already felt about 10C hotter than the software temperature reading), so I'm going to move my case fan to the bottom front (it was originally in the top front fan mount, but I moved it to the back).
Then I was trying to help my dad set up his new phone after the battery bulged on the old one (you might see why I added a phone rant to my post on laptop disassembly in that other thread). He got talked into buying a new 25W charger, which sounds ridiculous for a phone, but my phone has a 68W charging mode with a proprietary Qualcomm quick charger (I obviously don't do that and just reused the charger from my old Samsung S7). It might actually be good that phones don't include chargers because they'd probably come with the most ridiculous battery-killer option instead of something sensible.
Reply 1648 of 1649, by VanillaFairy
Today I've mainly done online shopping for parts for my retro build, mainly... I wish there was some thrift store for retro PC hardware around here in the UK, closest thing is CEX and they don't really do retro hardware unfortunately.
(okay, I did buy a CF card from there, although only a 32gb 60mb/s one. Should be plenty for XP or Vista at least, and if I need more I can just throw in a flash drive or a USB SSD since I'm getting a USB 3.0 PCI card too for this build in case I need the speed for testing it out with Linux. Still got to buy the fans, I'll probably cough up the money for Noctua's FLX fans, but otherwise... yeah)
Outside of that... I updated FreeTube so that viewing a channel's page works again, I guess that counts as a modern activity? Or swapping out Gboard for a FOSS keyboard on my phone, that's also a modern activity.
Just a silly lil person in a very big world.
Reply 1649 of 1649, by Law212
I found a nice NZXT H9 Flow Case with AIO at the thrift store for very cheap and am wondering if i should put my build into it or just sell it.
This is my current case. Which I liked for being very plain and not showing much of the internals.
And this is the H9 which is more flashy and more to showcase the guts.
I'm almost leaning towards this as the parts in the PC are very high end why not be able to look at them?
