Socket A: Aiming for the Stars!!!
Reply 240 of 642, by Repo Man11
My Soyo Dragon, one of my favorites, a project that turned out well. I've played through Max Payne and Half Life on this system. After I had recapped it, I found there was a mod that could be done to allow the use of throughbred core CPUs (fellow Vogons members helped me track down some information that had been lost). I tried an Athlon mobile with it, but it was hit or miss on POSTing with that CPU so I gave up on it.
I hadn't powered this thing on in a while - it takes longer to POST than any other motherboard I've ever had. It doesn't seem to be a problem, just a quirk with this board, but you start to get nervous when you hit the switch and hear nothing but the fans for longer than you'd expect.
Reply 241 of 642, by supercordo
Repo Man11 wrote on 2026-06-07, 18:47:
My Soyo Dragon, one of my favorites, a project that turned out well. I've played through Max Payne and Half Life on this system. After I had recapped it, I found there was a mod that could be done to allow the use of Palomino core CPUs (fellow Vogons members helped me track down some information that had been lost). I tried an Athlon mobile with it, but it was hit or miss on POSTing with that CPU so I gave up on it.
Need to select 1M in SuperPi before running the benchmark.
Reply 242 of 642, by Repo Man11
supercordo wrote on 2026-06-07, 19:16:
Ah, I didn't notice, I've never used that benchmark before, thanks!
Reply 243 of 642, by supercordo
Repo Man11 wrote on 2026-06-07, 19:20:
You also need Super Pi Mod v1.5 XS. Its the second one down with the link on the first post.
Reply 244 of 642, by Repo Man11
supercordo wrote on 2026-06-07, 19:41:
Third time is a charm!
Reply 245 of 642, by supercordo
Where you guys at????
Reply 246 of 642, by zuldan
supercordo wrote on 2026-06-10, 21:10:
I’m joining the competition. Couldn’t resist. Started with a 6600GT but it’s too slow to hit 20k+ in 3DMark. Going to swap it with a 7600GT then post some results.
The attachment IMG_0768.jpeg is no longer available
Reply 247 of 642, by supercordo
Nice, welcome to the fun.
Reply 248 of 642, by PcBytes
I'm still on the sides. Almost ready to snag a X800 but I still need a few more $$$ as I have some Pentium III projects on the sides, as well as maybe stocking on some XP-M chips - some advice on which XP-M to get would be welcome.
I do have the NF7 and 7N400 Pro2 ready.
Reply 249 of 642, by cyclone3d
PcBytes wrote on 2026-06-10, 22:02:
2500+ seems to be the easiest good chip to find though good prices 2800+ come up every once in a while.
I am about to join the fun in hopefully not too long.
Have some more good RAM on the way and also an NF7 v2.0 which I hope is working.
Already have a couple A7N8X v2.0 (nforce 2 Ultra) as well as an EPOX 8VTAI (Via KT880).
Will also probably post some dual socket runs as I have a board with dual 2600+ in it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 250 of 642, by tehsiggi
Give a man a break 😉
Jk, had to wait for caps etc. to arrive for my K7S8X Rev3 - it runs 200+ MHz FSB without issues. Time for memory and chipset voltmods - but I was able to squeeze a lot more out of the T-Bred 2400.
The attachment tbred_k7s8x_15612.JPG is no longer available
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 251 of 642, by _digitalbath
I am busy with my real life.
I bought a DFI NFII Infinity board last week. It’s not quite where I’d like it to be for a good benchmark run yet. I’m considering using my best XP-M for a SuperPI 1M run.
zuldan wrote on 2026-06-10, 21:37:
Nice XFX card! I used the same card. I like it a lot.
Look out for IDYHA / IQYHA / IQYFA / AQYHA steppings.
tehsiggi wrote on 2026-06-11, 05:43:
I think that’s a good result for a 746FX chipset. The 748 chipsets aren't significantly better. OC FSB depends highly on the multi. Going from ~240MHz @6x and slowest romsips to barely 200MHz / 11x and fastest romsips.
The chipset voltage on my board didn't change much; I increased it from 1.8 V to 2.0 V. The chipset seems to run significantly hotter then.
A memory voltmod would be interesting for me.
Reply 252 of 642, by tehsiggi
_digitalbath wrote on 2026-06-11, 10:05:
+1
Got the board to 212MHz FSB with the T-Bred A - memory etc. is a topic as well, of course. The BIOS - for whatever reason, does some funny things with the timings, even if hard-coded. But hey, it is what it is.
With 212MHz though I did not get more points in 3DMark01SE - even though I then had nearly the same CPU frequency. Will have to try some more - but life calls as well 😉
For the Voltage-Mod - I'll post it here once done, not too big of a deal. Interesting enough, the K7S8X already runs the memory at 2.7V per default.
Reply 253 of 642, by tehsiggi
The attachment tbred_223_pi.JPG is no longer available
Here's a run of SuperPi with the T-Bred 2400 overclocked. All on the K7S8X Rev.3.0 - I think this is where the journey of that tbred ends..
Reply 254 of 642, by PcBytes
So I went ahead and bit the bullet on a 7600GS I previously used. Couldn't find GTs, the X1950 was way too sketchy for its price and X800s have gone crazy in prices.
I guess I'll mod it for active cooling then see where OC takes me.
Reply 255 of 642, by _digitalbath
tehsiggi wrote on 2026-06-11, 12:35:
thanks!
you can use cheepomemtweak to look at the timings.
Reply 256 of 642, by tehsiggi
_digitalbath wrote on 2026-06-11, 18:26:
thanks!
Thanks, I'll give that a try the next days!
Here's the latest SuperPI run:
The attachment 210_plat_pi4.JPG is no longer available
PcBytes wrote on 2026-06-11, 16:24:
Wild to think that I just bought my X1950GT for 25€ 5 years ago..
Reply 257 of 642, by supercordo
Scores have been updated.
Reply 258 of 642, by cyclone3d
Going through my AGP cards. I already knew I had the Radeon 3850 and the Gainward 7800 GS ( really 7900GT ?). Completely forgot I had a 7950GT.
Pretty sure I have a Radeon 4670 as well.
This gon git gud 😁
I'll test with other high end AGP cards as well for the fun of it.
YMF7x4 Guide
Reply 259 of 642, by supercordo
cyclone3d wrote on 2026-06-12, 01:25:
Going through my AGP cards. I already knew I had the Radeon 3850 and the Gainward 7800 GS ( really 7900GT ?). Completely forgot […]
This gon git gud 😁
Welcome to the fun!!!!
