First post, by VanillaFairy
- Newbie
Iiiit's me again, with my wonky OEM Sony Vaio motherboard I'm making a retro system out of.
I noticed somewhat recently that the motherboard (ASUS P4S533-VX) has two 4pin connectors; one by the 20pin ATX power connecter, and one by the CPU socket.
The one by the socket is labelled "ATX12V1", with the one by the ATX connector being labelled ATX12V2...
would both need to be connected?
They're the same plug shape, and both labelled as 12V. if both were needed, would a 4pin splitter suffice? (or, I guess an 8pin to dual-8pin, since the PSU I chose is a modern one and has an 8pin CPU connector)
And if only one is needed, would that give any worse performance with a higher clocked CPU?
(The CPU I managed to somehow get my hands on for cheap enough was a Pentium 4 HT 3.06. (with a 533MHz frontside bus), which I think should be the best this motherboard can actually do since it has a max bus speed of 533 MHz.)
Just a silly lil person in a very big world.
