First post, by voodoodrul
I’ve experienced this with every sb live card I have, but I don’t hear much about the tempo/pacing/timing issues when people refer to sb live cards and the lackluster fm synth. Are certain models or hardware combinations more or less prone to this issue? I’ve tried a variety of drivers and some cause opl2 to run slow as well. Opl3 in Descent plays about 50% of the speed it should run at. This is on a p3 600 slot 1 with a 440bx.
I’m mostly just looking for context on the issue if anyone has the knowledge.
Reply 1 of 6, by Joseph_Joestar
voodoodrul wrote on 2026-06-13, 05:50:
While the SBLive FM Synth emulation does indeed have slowdown problems (which may depend on the driver version), Descent is not a good example to test this. The music in that game slows down even on sound cards with genuine OPL3 hardware. Relevant info in these threads:
Anyone have a idea why the music tempo in Descent fluctuates so bad on OPL?
Re: Opti 82C929A - DOS driver anyone please?
As for the SBLive issue, I found that using the Audigy DOS drivers can mitigate the slowdown, at least in some games. See my guide for more details.
My retro builds
Reply 2 of 6, by voodoodrul
Joseph_Joestar wrote on 2026-06-13, 06:09:
While the SBLive FM Synth emulation does indeed have slowdown problems (which may depend on the driver version), Descent is not […]
The legend himself 😂 - Thanks. I ended up going combo SB Live and YMF744 with SB-Link. I never used to have issues with OPL2 or 3 in Windows with the Live, but even that was getting laggy with weird instruments. So I decided to give up and let the Live do Windows only, YMF do DOS only.
I guess the part that was surprising to me is how different each model of SB Live (even with same EMU10k1) can sound and how unpredictable it can be. Previously I was not swapping between models to side-by-side compare, but CT4780 sounds very different from SB0060, even on the same driver versions. A table of best model + driver combos would be interesting, even if subjective.
Reply 3 of 6, by leileilol
oh it's definitely a real issue. it's not real opl3 so it struggles emulated with huge timing. It definitely happens on live 5.1 and i've never recommended this card for dos. I got sick of this issue in 2001 (begrudgingly going GM where I can) and had started to hope for something like a dos emulator to exist as I feared these issues would get worse.
Reply 4 of 6, by NeoG_
leileilol wrote on 2026-06-16, 04:27:
oh it's definitely a real issue. it's not real opl3 so it struggles emulated with huge timing. It definitely happens on live 5.1 and i've never recommended this card for dos. I got sick of this issue in 2001.
There is a significant improvement using the later audigy driver package for Live cards in DOS, it doesn't slow down OPL like the Live drivers
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 5 of 6, by Riikcakirds
isn't it mentioned in old threads on Vogons that when using the sbeinit emulation picking OPL2 in games that offer it instead of OPL3 makes the sound more accurate ? (most dos games almost always use OPL2 anyway)/
Reply 6 of 6, by leileilol
i've heard the slowdown on opl2-stuck games, i don't think it'd matter. The slowdown's much like the earlier AudioPCI ECW-based TSR behavior.
