First post, by kotel
While back I got an broken Palit HD 2600 XT with artifacts. I though it would be an simple core + mem reflow and it'd work, but my judgement was veeery off....
I plugged the card in, artifacts as expected (R/G/B dots with some jittering around the screen, corrupted text). I have reflowed the memory thoroughly and the die of the core. Sadly, I only made it worse.
My only reasonable course of action was another reflow of memory and core. I did it but to no avail. Same artifacts.
Then I had an briliant idea of running the GPU without the cooler just to see if it would get detected. PC was booting normally until it just froze on POST code 98. With an known good GPU inside the mainboard works fine.
I have tried another board, but this one doesn't see this GPU completely. After some probing with the experience from my previous 2600XT I noticed a few shorted caps (see attachment "1" and "2"). Sadly, I couldn't find the cause of it so I looked at the caps on the core. All of the ones facing the PCIe slot show <0.8ohms (they should show at least >2ohms).
Now, my question is, is this card's core really dead?
I couldn't save them, but that doesn't mean I can't save myself!
Ready yourself!
Reply 1 of 1, by kotel
Armed with the knowledge from the attempted repair on my gtx660 which suddenly killed all the mem chips alongside the core, I went ahead and removed the coils as a form of troubleshooting, all of which were dead short to GND.
After removing them, the short persisted only on the side connecting to the core and memory. The side connected to the MOSFETs had high resistance. Removed the filter caps and they weren't the culprit.
So I guess this seals the fate of this card then. I'll try removing one memory chip and see if it is shorted internally. High chances it is, but I still have some glimmer of hope for them.
Ready yourself!
