Reply 220 of 222, by wbahnassi
- Oldbie
Condor.07 wrote on 2026-06-14, 23:34:Any game with Vortex 1, only Music works, SFX never works. From what I understand I think the problem is with the motherboard, I have an AsRock X58 Extreme6. I think the only one is Yamaha. I should point out that the driver installs without any problems.
I just tried a Vortex 1 on my machine and it worked fine, both FM and SFX in real DOS. So it is probably a kink in your motherboard setup. Maybe try other PCI slots or play with IRQs (5 vs 7)...etc.
I also tried both SBEMU and VSBHDA and both failed miserably. SBEMU loads but hangs on the moment a game loads, and VSBHDA hangs on loading it in Autoexec.bat...
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
