Reply 20 of 22, by chubabs
PC Hoarder Patrol wrote on 2026-05-10, 12:54:I tried a similar mod a few years back for another member here, with a similar level of success as your own. Feel free to try / […]
chubabs wrote on 2026-05-10, 12:08:Coppermine 1 gHz also booted in the FCPGA2 package, on the 370CPU slockets; I think the problem is with the microcode after all. […]
CPUID=6B1 Rev=1C 2001/02/15 CRC=6506E1CF Off=1026D Size=800 Plat=4
CPUID=6B1 Rev=1D 2001/02/20 CRC=6D9B5661 Off=10A6D Size=800 Plat=5
These are the ones I managed to find; maybe someone can suggest or share what other microcodes exist for TualatinsI tried a similar mod a few years back for another member here, with a similar level of success as your own. Feel free to try / compare my version with yours...
Far as slockets are concerned, this generation of Supermicro boards had a rep for being brand / model picky regarding what would work (modded or otherwise), ranging from 'just don't bother' (ABIT SlotKET III) to 'top rated' (ASUS S370-DL). Where the 370SP rev 2.0 falls in that range I couldn' say.
Thank you for sharing your research; I'll try testing this BIOS.
