First post, by telengard
Long time lurker, first time poster...
It's available here, hopefully some folks on here might find it useful.
https://telengard.itch.io/crustybasic
It's the first release with support for DOS so there may be some things not working right... if so, let me know and I will fix! There are lots of examples included to get you started. All that is needed is to stage nasm as mentioned in the docs.
Any feedback/ideas/bug reports appreciated!
~telengard
Reply 2 of 7, by telengard
No problem
I can't seem to edit the post, but yes full disclosure... I do use AI as like a "peer programmer". This isn't a vibe coded project, but I do have the LLMs help with writing code, unit tests, bouncing ideas off, making A/B tests for perf, etc.
Reply 3 of 7, by BinaryDemon
I might have to give this a try. I like the idea of cross-compiling between so many different systems.
Reply 4 of 7, by vetz
telengard wrote on 2026-06-17, 00:15:
No problem
Thanks for clarification! Really liked the ASCII art you made for the project
Reply 5 of 7, by telengard
BinaryDemon wrote on 2026-06-17, 11:41:
If you do, definitely let me know if you have any issues, etc. I'll be adding a lot more systems in the future as well as improvements. PCjr and Tandy 1000 are mostly done, but they weren't totally ready so they weren't in this last release.
Reply 6 of 7, by telengard
I put out a new release today, relevant are QBasic and GWBasic are supported dialects. Lots of other changes too, 2 new targets (C128 and Windows x64).
